04-20-2024, 11:44 AM | #1 |
2024 BMW iX xDrive50 (iDrive 8.5)
24
Rep 30
Car not respecting the charge times
Hi I have a 2024 BMW ix xdrive50 I drive 8.5
I have a charging schedule that excludes 4pm to 9pm. Previously I used to make sure my charger never allows charging in this schedule. But later I removed it and let the car do it. It worked correctly initially, but recently I am noticing otherwise. The car is charging during peak hours. Has anyone else had this same issue? I previously had this issue with charge forward that caused random charging but I removed myself from it. Screenshots attached. Any thoughts ? |
04-20-2024, 12:37 PM | #3 |
Rep 284
Is it possible to set different charging times
For example on my Mach E I can set a charge zone for Monday- Friday and I different one for the weekends. My cheaper rates are 9 pm- 10 am during the week and 24/7 on the weekends. |
04-20-2024, 12:42 PM | #4 |
Rep 960
Drives: ix xDrive50
Could the preconditioning request trigger charging? Can you try it with preconditioning turned off and see if it behaves differently?
04-22-2024, 03:56 PM | #5 | |
Rep 1,994
The reason is that you plugged in at 6:23pm and have a scheduled departure time for Thursdays at 6h30pm. I don't use time slots to charge myself, but my understanding is that the car will ignore the time slot in order to have the car at the target charge you have set for a pre-planned departure time. So if this was all done on Thursday, the car thought you needed to have a 80% charge for 6h30pm and so it ignored the time slot. But if this wasn't on Thursday, and you haven't changed the settings, then I don't have an explanation. If to you it is more important to only charge in the specified time slot, your best bet is to use a home charger that offers this functionality (who will have no idea at what SOC the car is and thus cannot use it in its own logic to override the time slot)instead of setting it up in the car as the car is known to override it on occasion and can possibly misbehave if your own example wasn't from a Thursday. |
