      01-27-2019, 10:27 PM   #1
NashvegasR
Drives: 2016 M4 F83
I3S - fender flares
I haven't confirmed that they come primed or unpainted (one site realoem says painted, another says primed)... but does anyone know how they attach. Fasteners? Adhesive tape (likely?)
If they just have adhesive should be an easy mod and they're not that expensive.
      01-28-2019, 06:25 PM   #2
note46
Drives: M Coupe, 328d SW, i4
according to realoem it's attached with screws: pn 07147304573
in realoem when you see part numbers in a circle, it means that those are the subparts needed to attach the main part.
      01-29-2019, 06:25 PM   #3
NashvegasR
Drives: 2016 M4 F83
thanks. darn !
      01-30-2019, 04:12 PM   #4
note46
Originally Posted by NashvegasR View Post
thanks. darn !
don't give up yet! the screw might be using an existing hole for the fender liner. Wont know until you take a look at a S and compare with the non S
      01-30-2019, 04:56 PM   #5
PBNB
Drives: 2015 i3 REX
I was thinking the same possibility. If you assume that both models start off with the same fenders, and there are no holes in the fenders in the non-S models, it would make sense that the flares attach discretely.
I hope the holes in the fender liners are the answer.
      01-31-2019, 09:39 AM   #6
Vitalität
Vitalität's Avatar
Drives: BMW i3 & X5
2015 BMW i3 BEV  [0.00]
2007 BMW X5 48i  [0.00]
2006 BMW 330i  [0.00]
2004 BMW 330i  [0.00]
It can be done guys but a lot of your time and fabrication is needed. Not worth your while unless you are patient guys.
Garage: BMW i3 Giga World BEV | BMW E70 X5
      01-31-2019, 12:16 PM   #7
ARQVE36
Drives: BMW E91
It looks great! Do they come in gloss black? Are they use clips or double side tape to hold on the fenders?
      02-20-2020, 02:04 PM   #8
Nunaat
Drives: E34 525tds F33 420d I01 bmw i3
Hi, I have the pieces and the truth is that I see a lot of complication putting them. how have you done Have you lowered the pieces from behind and then hit and screwed? Or have you made holes and grooves in the car body? I appreciate your help.
