04-21-2024, 03:48 PM | #1 |
Rep 41
First Time Charging need help
I have the BMW wall box and when I plug the car in the light stays white. There is a blue light that’s steady on the wall box and the car and app recognizes that that it’s plugged into car. There is something on the app that says it’s “unlocked”. Am I doing something wrong?
In meantime I plugged in the charger that came with car but car is outdoors. Is this charger ok to be outside? |
04-21-2024, 04:25 PM | #2 |
Rep 1,499
Drives: 2023 iX xDrive50
The portable EVSE is fine for use outside but be careful someone doesn't walk away with it.
Does the portable EVSE work and is the problem just with the mounted wall box? The steady blue light suggests that the wallbox thinks it's not plugged in to the car. https://cdn.flow.page/images/e264c4a...f?m=1681152030
Past BMW's
2020 M850i GC | 2020 X5 | 2018 M550i | 2017 X5 | 2014 535d | 2013 X5 | 2007 530i | 2002 X5 | 2000 540i/6 | 1999 M Roadster | 1989 535i | 1984 533i | 1983 533i | 1977 530i Last edited by Pictor; 04-21-2024 at 04:34 PM.. |
drbluedevil864.00 RichardInCA2568.00 |
04-21-2024, 04:47 PM | #3 |
Rep 41
I thought the steady blue light on wall box means it’s ready.
The wall box does not charge but the portable does. I unplugged the wall box to use the portable. When I use the wall box the car and app indicate it’s plugged in but no charging happens. I had schedules set up but I deleted all of them and I set it for immediate charging but still does not start. It says something about it being “unlocked”. Does it have to be locked to start charging? |
04-21-2024, 05:10 PM | #4 |
Rep 277
Are u sure its not charging or just charging real slow. Check the amp setting on your BMW app or in the car, everytime I charge with AC at a new place I have to increase it from 6 amp to 48 to get the max charge
04-21-2024, 06:27 PM | #5 |
Rep 1,499
6amp is the default in the wallbox (according to the manual link above). If the wallbox is only pushing 6amp then the dip switched in the wallbox need to be adjusted to the correct setting for the circuit.
I've never had to readjust the setting in the vehicle. It's set to 48amp in the vehicle and every time I plug into a L2 EVSE, I get the max it's able to deliver up to 48amp.
Past BMW's
04-21-2024, 07:11 PM | #6 |
Rep 41
Even it it was charging slowly it would say it’s charging. This is saying it’s plugged in when wall box is connected but not charging. When I plug in the portable it starts charging right away. Car is set to 48v
04-21-2024, 07:25 PM | #7 |
Rep 616
It sounds as though charging is not initiating as Pictor notes above. I have a Wallbox hardwired into my house and the charging port light (i5 in my case) and wallbox light both flash blue when charging is occurring.
Did the installer check that the authorization DIP switch was turned off? (Per below it’s set to “on” at the factory) |
04-21-2024, 08:09 PM | #9 | |
Rep 277
04-21-2024, 08:10 PM | #10 |
Rep 277
True, I just thought I would mention to look at the amp anyway.
04-21-2024, 08:12 PM | #11 | |
Rep 41
04-21-2024, 08:25 PM | #12 | |
Rep 616
That authorization app is not supposed to be available in the US market at this time - I’m not sure whether that would be the wallbox service app, or some other app, but it’s not the myBMW app. |
04-22-2024, 10:56 AM | #13 |
Rep 41
Hi everyone. It was the DIP settings. electrician came by and changed them thank you
Pictor1718.50 RichardInCA2568.00 |
