      07-01-2023, 02:01 AM   #1
shmaze
Drives: BMW i3
Programming/Coding help needed bmw I3
Hello
I bought a BMW i3 2017 94ah with range extender second hand. The car is US version, and I knew that car was in accident with driver airbag deployed.
Updated all modules with new psdz data with e-sys and unfortunately coded the ACSM4 module so all previous setting were gone.
After coding and resetting the settings, I encountered several errors with ACSM module.
1. 930994: Safety battery terminal: Resistance too High
2. 93090A: Driver's airbag, interval stage 2: Resistance too high
For error no 1 - I checked the terminal it was gone (fuse exploded). For safety reasons purchased BST terminal repair kit and error is gone.
For error no 2 - I called the old owner, was told that he replaced the deployed airbag with a brand new one for European I3 version, it had to be coded because the airbag in US i3 are 2 stage and Europe versions use one stage airbags. I made a visual check of the airbag install and it is looking intact.
As I understood ACSM module needed to be coded. I purchased bimmerutility, have E-sys latest version + Ista 4.41 with latest psdz databases 4.42.11.
Unfortunately I cannot find the setting in ACSM CAFD file from where I can switch from 2 stage driver airbag to 1 stage airbag.
Would be very helpful if anyone will give me an advice and directions.
      07-02-2023, 09:21 PM   #2
maaii11
Drives: Mini F54
ACSM Module 3000
Function-airbag_fahrer_stufe_2-> set to nicht aktiv
Adaptive_airbag_fahrer_vent-> set to nicht aktiv
https://f30.bimmerpost.com/forums/sh....php?t=1284340
