10-24-2017, 12:04 AM | #1 |
Rep 14,109
Drives: G82 M4C X-Drive
Video Playback is inconsistent
Some of my video files play fine, but others play back with a lot of video artifacts, as if the i3 can't read the video fast enough. Looks like pixelation.
- The exact same video files play back on my M3 perfectly while being buggy in the i3 - The exact same video file on the exact same usb thumb drive plays on my M3 perfectly while being buggy in the i3. - Other video of the same file type (mp4, m4v) playback fine, so it's not that. - All my videos are h264 - Data rates don't show a pattern. Some of my high bit rate files play fine, while some low ones don't and vice versa. - I've tried different USB thumb drives, same result. Anyone have this same problem? Any fixes? Video formats that work for sure? What version iDrive does my 2015 i3 have? I want to check other BMW model forums to see if they have the same problem.
10-24-2017, 12:48 AM | #2 |
Rep 108
Can video be played through the idrive without coding? I haven't tried loading anything from a usb I just use Bluetooth. If it can play mp4 from a usb I will try this over the weekend.
10-24-2017, 12:50 AM | #3 |
Rep 14,109
It can, but you have to be parked. My i3 is coded.
10-27-2017, 12:09 AM | #4 |
Rep 8,364
Coding is required to enable additional codecs. But, some will play from factory.
10-27-2017, 12:19 PM | #5 |
Rep 108
Thanks, that's helpful information. Do you know any specific codecs that work or fail? I have everything in mp4 or iTunes format, and I can accept having to reformat once or twice in testing but would prefer to avoid known problematic codecs.
Maybe it's the underlying codec that is the trigger issue for OP. |
10-27-2017, 09:13 PM | #6 | |
Rep 8,364
These can be enabled: OGG, XVID, VCD. |
