03-13-2015, 01:50 AM | #1 |
Rep 73
USB Cigarette charger that fits!!
The USB charger built into the car seems is not powerful enough to charge my phone w/ GPS running. But of course the cigarette lighter is positioned that any normal USB charger is too tall to close the armrest.
Well.. I found a solution! This is short enough that will work. This is for android phones. http://www.aukey.com/product/usb-car...r-adapter-ccs1 so then I bought this 90 degree micro USB cable. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 If you have an iphone (editing as the last one i recommended didn't work) you might want to try one of these http://www.amazon.com/s/ref=nb_sb_no...ee+usb+adapter then your lightning cable. Yes, different wiring for iphone vs. iphones. for iphone cable lightning this should work http://www.amazon.com/EMTEC-Ninety-i...e+iphone+cable now, you can have a charging cable that fully charges your phone at full amperage/wattage with the armrest closed Last edited by gadgetfreaky; 04-08-2015 at 12:20 AM.. |
03-13-2015, 05:27 PM | #3 | |
Rep 338
i8 2014 (PI, Protonic Blue), X1 25i 2016. Gone F30 320i xDrive 2013, E84 X1 23d 2010, E60 530 xdA 2006, E92M3 2008, R53 Mini Cooper S 2006, F430 F1 2008
03-16-2015, 04:47 AM | #4 |
Rep 73
yes.. installed. fits perfectly when closed & more importantly high wattage charging! go ahead and let Waze direct you & you'll still charge. I do wish BMW had designed a way to use waze instead.
03-16-2015, 10:24 AM | #5 |
Rep 338
Thanks for info! Tolerance is really small so selecting the right gear is relevant. This is perhaps the first and so far only detail that I would have changed in i8 design.
04-07-2015, 04:39 PM | #8 |
Rep 12
I purchased the cigarette lighter for iphone and the 90 degree lighting cable and I can not get the arm rest to close. Has anyone been able to get the arm rest to close with this combination?
Thanks |
04-07-2015, 05:48 PM | #9 |
Rep 25
I agree. I purchased the combo for the iphone with the lightning plug and the lid does not close; gave up and plugged it into usb port
04-07-2015, 06:41 PM | #10 |
Rep 678
Drives: E30M3, E39M5, SLSAMG, RRS SVR
Garage List 2015 Range Rover Sp ... [0.00]
'03 BMW M5 [0.00] '88 BMW M3 [0.00] '84 Toyota Corolla ... [0.00] '14 Ford Fiesta ST [0.00] '12 Mercedes SLS AMG [9.83] |
Belkin's 2amp/10-watt chargers worked for me (enough power for an ipad if you wanted). Fairly low profile and high quality.
http://amzn.com/B00LETJDNQ |
04-08-2015, 12:19 AM | #11 |
Rep 73
I'm sorry! I have the android and that works perfect. I assumed the lightning cable would have worked. you'll have to find a iphone cable that has a 90 degree to it. or maybe a 90 degree usb adapter. maybe one of these will work
http://www.amazon.com/s/ref=nb_sb_no...ee+usb+adapter |
04-08-2015, 12:21 AM | #12 |
Rep 73
also, on the bmw i8 facebook group, I just learned there's another cigarette light adapter on the passenger side below the glove compartment! Not home to confirm but give that a try.
04-08-2015, 04:06 PM | #13 |
Rep 25
You are correct. There is an open cigarette lighter socket under left side passenger area;
04-24-2015, 11:08 PM | #14 |
Rep 8
omg you saved my day!
Owner of both 2012 + 2014 Audi R8 V10
+ 2014 Audi A6 + 2012 Audi Q7 + 2015 BMW i8 || Instagram: gcseed |
04-26-2015, 05:13 PM | #15 |
Rep 1,646
04-26-2015, 06:42 PM | #16 |
967
Rep 1,723
It's at page 132 of the Online Edition Owner's Manual that has part number 01 40 2 960 891 -II/15. I haven't looked to see if it's in the Manual in the car (because I am lazy). It's in the Controls/Interior Equipment section.
05-26-2015, 12:36 PM | #19 |
Driver
301
Rep 382
It isn't worded very well, but I think what they mean is that you should not attempt to charge the car's 12V battery via the CLA or USB ports. That is, don't use external trickle chargers. Only charge the i8's batteries via the J1772 connector.
05-26-2015, 04:26 PM | #20 | |
Rep 774
Do not connect charging devices to the 12 volt socket in the vehicle Do not connect battery chargers to the factory- installed 12 volt sockets in the vehicle as this may damage the vehicle battery due to an increased power consumption.◀ Do not use the USB interface for recharging external devices. How would charging the cars battery increase its consumption? I have to disagree on this one, I think they are talking about using the sockets for charging an external device. Thoughts anyone? |
10-23-2016, 08:23 PM | #21 |
Rep 120
quick update about options
I tried at least 3 different brands with side cables and this one confirmed and would be the best option for your i8 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 it has low profile 12V plug that will keep your compartment closed and cable running down any place you want with usb hub for 4 charges
96 520i, 99 330i, 00 325i, 03 X5 3.0i, 06 X3 3.0i, 07 530i, 09 X5 4.8i, 10 M6 Conv, 11 X5 50i,
11 535xi, 14 X5 50i, 14 328xi GT, 16 X6 50i, 16 i8, 2019 X5 40i, 18 328d xi, 21 X5 40i, 22 X6 40i |
10-24-2016, 01:34 AM | #22 | |
Rep 1,177
