08-31-2016, 04:48 AM | #1 |
OG
28
Rep 42
BMW I8 headlights
Ok I've had the I8 for a few months now and absolutely love the car. I really don't do much driving at night but one of my issues is that the ighting is not bright enough and especially around corners. I love the lights on my M4. Granted I did have the lighting package, I would expect the I8 to be just as good if not better. just wondering if anyone is experiencing the same. If anyone has opted for the new laser lights please feel free to comment if they're happy with it.
08-31-2016, 05:09 AM | #2 |
Rep 407
Spooky timing, I have had my 2014 for a few months and I'm happy with the brightness but was just wondering if anybody can confirm if the headlights should swivel around corners?
I'm booked in for a fuel system problem next week and wanted to know if the headlights need checking as well. I used to have a 635D and loved the swivelly headlights!
2014 i8
2002 x5 4.6is |
08-31-2016, 09:54 AM | #3 |
Rep 174
Standard lights and not had an issue with light levels at night.
I do activate auto beam though - have you tried this? It can sustain a higher overall light level even with oncoming traffic, as it cuts out specific blocks of light only where it is needed to avoid dazzling oncoming traffic. Not in car, but I think you activate it by pressing and holding the 'A' on the indicator stalk. |
08-31-2016, 10:04 AM | #4 | |
Rep 1,405
08-31-2016, 10:17 AM | #5 |
Rep 4,128
Drives: M235i & G30 540i
Thing about the laser lights is its high beam only. Which to me kinda sucks since most of the time you drive with low beams. I also find it somewhat of a gimmick because of this. Not exactly, but I was considering the laser lights until I found out its high beam only.
But you shouldn't have a problem seeing with the low beams at all.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
08-31-2016, 10:22 AM | #6 | |
OG
28
Rep 42
08-31-2016, 10:23 AM | #7 | ||
Rep 4,128
08-31-2016, 10:29 AM | #8 | |
Rep 571
08-31-2016, 10:44 AM | #9 | |
OG
28
Rep 42
- 20" BMW I light alloy wheels T - LED Headlights w/cornering So technically they are supposed to swivel. Also off topic I did have my I8 coded and activated the rear fog lamps and swapped out the headlight switch with a European switch. |
08-31-2016, 11:05 AM | #10 |
Rep 174
For modern led headlights, surely they don't need to actually swivel, as they operate on a matrix system - that how they cut out blocks of light, isn't it?
So, for instance when you turn, the most extreme edges of the matrix should light up. I'll pay more attention next time I'm driving at night to see if this is the case in either dipped or 'A' headlights. |
08-31-2016, 01:27 PM | #11 | ||
Rep 4,128
08-31-2016, 04:34 PM | #12 |
OG
28
Rep 42
I thought i was answering my own question in assuming the I8 is like the M4 in the sense that US specs are set to about 70% brightness. I however was just speculating. Does anybody know if this is true for the I8 in the US? Also funny how when pulling my car in the garage at night or when it's not to bright out, I can see the projection of the headlights moving left and right in both my 5 and M4. I don't see this on the I8. was playing around turning the steering wheel left and right and nothing, nada, zilch, no movement from the headlights. has anybody noticed if it swivels like i think it supposed to? if so then there's my problem. please chime in if you try to test this
08-31-2016, 05:46 PM | #13 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
I thought the swiveling was always called "Adaptive Headlights". Cornering is just using the fog light.
BMW USA website doesn't list either option for the i8. I was under the impression that coding them for the anti-dazzle was the only way to get this feature. |
08-31-2016, 06:19 PM | #14 | |
OG
28
Rep 42
PLEASE NOTE: You have selected the following: BMW Laserlight By adding this selection, you will also: Remove LED Headlights with Cornering Lights$0 NO, DO NOT CHANGE YES, CONTINUE Also my window sticker clearly states the same. Im not sure where you were looking, but I8's don't have front fog lights. My wife's 5 does not have the extra $2,000 lighting package that my M4 does and the 5 series has "Xenon Adaptive headlights with LED rings and cornering" but regardless they both pivot, swivel turn whatever the hell its called lol and the I8 does not. Keep in mind that I had my I8 coded (with the exception of checking if brightness is also dimmed down to 70%) so rest assured we tried the anti dazzle code and it does not apply to the I8 it has a different lighting system. Point being did anyone test it to see if it moves left to right? |
08-31-2016, 11:49 PM | #15 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
09-01-2016, 03:39 AM | #16 |
Rep 407
On the subject of the 'swivel' function, my understanding of the spec according to BMW is that the headlights don't actually move (like they did on my older 635d using motors), but the LED matrix lights up different segments to help with corners.
With the motorized adaptive headlights, you could see the beams sweeping as you turn the steering wheel, very cool. And, when at a standstill, turning the steering wheel would also move the beams. I think on the i8, you don't notice a sweeping effect because a chunk of LED on the side is switched on/off to fill in the direction you're heading. I need to have a look from the front while someone is steering.
2014 i8
2002 x5 4.6is |
MalibuBimmer966.50 |
09-03-2016, 08:30 PM | #17 |
Rep 8,364
NA vehicles with adaptive headlamps have two decoding variables:
09-03-2016, 09:31 PM | #18 | |
OG
28
Rep 42
09-03-2016, 10:24 PM | #19 |
Rep 8,364
09-04-2016, 02:43 AM | #20 |
Rep 1,177
To me, this seems to mean: there's headlights, and then there's cornering lights. The latter may just be a little bit of light directed sideways (but fixed), so you don't turn into completely dark corners. Certainly doesn't imply that any thing moves or is adaptive.
09-04-2016, 09:42 AM | #21 | |
967
Rep 1,723
10-11-2016, 03:05 PM | #22 |
Rep 26
i have the laser headlights. i tried searching for a car without them. i couldnt find one without the laser option. now that i have them i love it and couldnt live without it. visibility is amazing.... and they look cool
http://www.instagram.com/luvjonesss
SOLD: 2012 BMW 328xi Sedan || 2013 BMW 335xi M-Sport Coupe || 2015 BMW 750Li xDrive M-Sport || 2016 BMW i8 Coupe CURRENT: 2020 BMW 750i xDrive M-Sport |
