02-23-2017, 03:05 AM | #1 |
Rep 244
Michelin Pilot Super Sport Tyres do they fit on front?
This has been going round the houses for some time, with no concise answer, just lots of debate on electric range, efficiency etc etc
Generally on the stock option tyres... I observe a community desire (I would prefer) to change the Bridgestone rubber to Michellin PSS. So lets go on the presumption we are changing the tyres.....cause they are awesome Has anybody actually fitted these to the 20" turbine or W-spoke alloys? This is only an issue for the fronts as there is the correct size available for the rear (245/40 R20) If so what Dimensions? Do they rub? Stock Front 215/45 R20 95W XL Nearest MPSS size I can find 225/35R20 Last edited by Mightymousemighty; 02-23-2017 at 09:31 AM.. |
02-23-2017, 09:15 AM | #2 |
Rep 10,855
OK I might cross-post some of this info. First, there are several variants of Michelin Pilot Sports tires that are possible options. Here is a list of sizes for the MPSS. Note the diameter for both front and rear is about 27.5, 755 revs per mile, and rim width for front 7-8". So we want a close match for that. A 235/40 would be good, but Michelin does not make that size. The best is 245/35 for diameter, but that is too wide for rim and clearance. 235/35 is a bit better for the stock front rim. I plan to go 235/35 front, 265/30 rear. That is a 26.5 diameter, 790 revs per mile, 2" wider tire set up. Tire weights (22 lbs, 24 lbs) are the same as stock size. Definitely going to reduce gas mileage though.
for comparison, data on OEM front Bridgestone S001 l: 215/45R20 95W XL Star BMW 280 A A 1,521 lbs. 50 psi 8/32" 22 lbs. 7-8" 7" 8.4" 6.5" 27.6" 754 PL Michelin PSSS: 225/35ZR20 (90Y) XL 300 AA A 1,323 lbs. 50 psi 10/32" 22 lbs. 7.5-9" 8" 9.1" 8.8" 26.2" 793 FR 225/35ZR20 (90Y) XL 300 AA A 1,323 lbs. 50 psi 10/32" 22 lbs. 7.5-9" 8" 9.1" 8.8" 26.2" 793 FR 235/35ZR20 (92Y) XL K1 Ferrari 300 AA A 1,389 lbs. 50 psi 10/32" 22 lbs. 8-9.5" 8.5" 9.5" 9" 26.5" 786 FR 235/35ZR20 (88Y) SL 2011 Production 300 AA A 1,235 lbs. 51 psi 10/32" 22 lbs. 8-9.5" 8.5" 9.5" 9" 26.5" FR 245/30ZR20 (90Y) XL 300 AA A 1,323 lbs. 50 psi 10/32" 23 lbs. 8-9" 8.5" 9.7" 9.7" 25.8" 805 FR 245/35ZR20 (95Y) XL K1 Ferrari 300 AA A 1,521 lbs. 50 psi 9/32" 23 lbs. 8-9.5" 8.5" 9.8" 9.4" 26.8" 777 FR 245/35ZR20 (95Y) XL K3 Ferrari 300 AA A 1,521 lbs. 50 psi 9/32" 23 lbs. 8-9.5" 8.5" 9.8" 8.8" 26.8" 777 FR 245/35ZR20 (95Y) XL K2 Ferrari 300 AA A 1,521 lbs. 50 psi 9/32" 23 lbs. 8-9.5" 8.5" 9.8" 8.4" 26.8" 777 FR 245/35ZR20 (95Y) XL 300 AA A 1,521 lbs. 50 psi 10/32" 23 lbs. 8-9.5" 8.5" 9.8" 8.5" 26.8" 777 FR 245/40ZR20 (99Y) XL Star BMW 300 AA A 1,709 lbs. 50 psi 9/32" 26 lbs. 8-9.5" 8.5" 9.8" 8.7" 27.7" 750 FR 245/40ZR20 (99Y) XL 300 AA A 1,709 lbs. 50 psi 10/32" 26 lbs. 8-9.5" 8.5" 9.8" 8.7" 27.7" 750 FR 245/45ZR20 (103Y) XL 300 AA A 1,929 lbs. 50 psi 10/32" 26 lbs. 7.5-9" 8" 9.6" 8.5" 28.7" 726 US 255/30ZR20 (92Y) XL 300 AA A 1,389 lbs. 50 psi 10/32" 23 lbs. 8.5-9.5" 9" 10.2" 8.8" 26.1" 798 FR 255/35ZR20 (97Y) XL 300 AA A 1,609 lbs. 50 psi 10/32" 25 lbs. 8.5-10" 9" 10.2" 9.2" 27" 770 FR 255/35ZR20 (97Y) RF K2 Ferrari 300 AA A 1,609 lbs. 51 psi 7/32" 25 lbs. 8.5-10" 9" 10.2" 9.2" 27" 770 FR 255/40ZR20 (101Y) XL N0(Porsche) 300 AA A 1,819 lbs. 50 psi 9/32" 27 lbs. 8.5-10" 9" 10.2" 10" 28" 742 FR 255/40ZR20 (101Y) XL 300 AA A 1,819 lbs. 50 psi 10/32" 28 lbs. 8.5-10" 9.5" 10.2" 9" 28" 742 US 255/45ZR20 (105Y) XL 300 AA A 2,039 lbs. 50 psi 10/32" 29 lbs. 8-9.5" 8.5" 10" 9" 29.1" 716 US 265/30ZR20 (94Y) XL 300 AA A 1,477 lbs. 50 psi 10/32" 26 lbs. 9-10" 9.5" 10.7" 10" 26.3" 791 US 265/30ZR20 (94Y) XL Star BMW 300 AA A 1,477 lbs. 50 psi /32" 24 lbs. 0-0" 8.9" FR 265/35ZR20 (99Y) XL Star BMW 300 AA A 1,709 lbs. 50 psi 9/32" 25 lbs. 9-10.5" 9.5" 10.7" 9.7" 27.3" 761 FR 275/30ZR20 (97Y) XL 300 AA A 1,609 lbs. 50 psi 10/32" 26 lbs. 9-10" 9.5" 10.9" 10.1" 26.5" 784 FR 275/35ZR20 (102Y) XL 300 AA A 1,874 lbs. 50 psi 10/32" 27 lbs. 9-11" 9.5" 10.9" 10.1" 27.6" 755 FR 275/35ZR20 (102Y) XL Star BMW 300 AA A 1,874 lbs. 50 psi 9/32" 27 lbs. 9-11" 9.5" 10.9" 9.7" 27.6" 755 FR 285/25ZR20 (93Y) XL 300 AA A 1,433 lbs. 50 psi 10/32" 28 lbs. 10.5-10.5" 10.5" 11.6" 10.5" 25.6" 813 FR 285/30ZR20 (99Y) XL 300 AA A 1,709 lbs. 50 psi 10/32" 27 lbs. 9.5-10.5" 10" 11.4" 10.2" 26.8" 777 FR 285/30ZR20 (99Y) XL K1 Ferrari 300 AA A 1,709 lbs. 50 psi 7/32" 24 lbs. 9.5-10.5" 10" 11.4" 9.5" 26.8" 777 FR 285/30ZR20 (99Y) XL Star BMW 300 AA A 1,709 lbs. 50 psi /32" 26 lbs. 0-0" 9.9" FR 285/35ZR20 (104Y) XL K2 Ferrari 300 AA A 1,984 lbs. 50 psi 9/32" 30 lbs. 9.5-11" 10" 11.4" 10.1" 27.9" 746 FR 285/35ZR20 (104Y) XL 300 AA A 1,984 lbs. 50 psi 10/32" 30 lbs. 9.5-11" 10" 11.4" 10.5" 27.9" 746 US 295/25ZR20 (95Y) XL 300 AA A 1,521 lbs. 50 psi 10/32" 27 lbs. 10-11" 10.5" 11.9" 11.2" 25.8" 805 FR 295/30ZR20 (101Y) XL MO Mercedes 300 AA A 1,819 lbs. 50 psi 10/32" 29 lbs. 10-11" 10.5" 11.9" 9.4" 27" 770 FR 295/30ZR20 (101Y) XL 300 AA A 1,819 lbs. 50 psi 10/32" 29 lbs. 10-11" 10.5" 11.9" 11.5" 27" FR 295/30ZR20 (101Y) XL Star BMW 300 AA A 1,819 lbs. 50 psi 9/32" 29 lbs. 10-11" 10.5" 11.9" 11.6" 27" 770 FR 295/35ZR20 (105Y) XL K1 Ferrari 300 AA A 2,039 lbs. 50 psi 9/32" 30 lbs. 10-11.5" 10.5" 11.9" 12" 28.1" 740 FR 295/35ZR20 (101Y) SL K1 Ferrari 300 AA A 1,819 lbs. 51 psi 9/32" 31 lbs. 10-11.5" 10.5" 11.9" 11.6" 28.1" 740 FR 295/35ZR20 (105Y) XL N0(Porsche) 300 AA A 2,039 lbs. 50 psi 9/32" 30 lbs. 10-11.5" 10.5" 11.9" 11.5" 28.1"740 FR 305/25ZR20 (97Y) XL 300 AA A 1,609 lbs. 50 psi 10/32" 27 lbs. 10.5-11.5" 11" 12.3" 11.1" 26" 801 FR 305/30ZR20 (103Y) XL K3 Ferrari 300 AA A 1,929 lbs. 50 psi 9/32" 31 lbs. 10.5-11.5" 11" 12.3" 11.4" 27.2" 764 FR 305/30ZR20 (103Y) XL 300 AA A 1,929 lbs. 50 psi 9/32" 31 lbs. 10.5-11.5" 11" 12.3" 11.8" 27.2" 764 FR 315/35ZR20 (110Y) XL K1 Ferrari 300 AA A 2,337 lbs. 50 psi 7/32" 33 lbs. 10.5-12.5" 11" 12.6" 11.5" 28.7" 726 FR 315/35ZR20 (110Y) XL K2 Ferrari 300 AA A 2,337 lbs. 50 psi 10/32" 34 lbs. 10.5-12.5" 11" 12.6" 11.6" 28.7" 726 FR 325/25ZR20 (101Y) XL 300 AA A 1,819 lbs. 50 psi 9/32" 31 lbs. 11.5-12.5" 12" 13.2" 13.1" 26.3" 788 FR 335/30ZR20 (108Y) XL N0(Porsche) 300 AA A 2,205 lbs. 50 psi 9/32" 35 lbs. 11.5-12.5" 12" 13.5" 13" 28" 744 US 345/30ZR20 (106Y) SL 300 AA A 2,094 lbs. 51 psi 10/32" 35 lbs. 12-13" 12.5" 14" 12.7" 28.1" 716 FR
02-23-2017, 09:30 AM | #3 |
Rep 244
thanks mate realistically think the 225 and 235's are the only option due to the 7.5J alloy.
The 225/35R20 seems closest to stock size. |
02-23-2017, 12:41 PM | #6 |
Rep 1,177
I think this means you can do it. But your front will sit 18 mm lower than current (that's not a little if you're starting with a relatively low car) and you will introduce a speedo error (albeit on the "safe" side).
02-23-2017, 12:50 PM | #7 |
Rep 1,177
Now, I don't know about Scotland. But here in Switzerland, I would have to get this tire change checked and approved by the DMV / MOT, whatever you call it, because it's not listed as an approved size in the car's papers. Police here are occasionally fond of pulling people over and checking for correct tires, exhausts, lights, etc.
02-23-2017, 01:09 PM | #8 | |
Rep 170
__________
2016 BMW i8 2013 Audi Q7 2014 BMW 640iX GC (gone but not forgotten) |
02-23-2017, 04:22 PM | #9 | |
Rep 244
Otherwise you need to inform the insurance company |
02-23-2017, 04:24 PM | #10 |
Rep 115
No, it won't work because the car will read more revolutions on the front axle then the rear, thinks it's spinning constantly and traction control will be
02-23-2017, 04:24 PM | #11 |
Rep 244
The point about the front being lower for kerbs is a very good point.
02-23-2017, 04:42 PM | #12 | |
Rep 244
Would they fit on a 7.5J alloy? Is 8" not minimum? Expert opinions please |
02-24-2017, 04:10 AM | #13 | |
Rep 407
traction control to kick in more often especially when in "e-drive" mode. My front end is very fond of breaking traction with the stock size and sticky s001 compound. Don't know if it would be noticeable though....guinea pig time !
2014 i8
2002 x5 4.6is |
02-24-2017, 10:00 AM | #14 |
Rep 10,855
In general it is a good idea to keep the diameter ratio constant (same as OEM) between front and rear. Hence my suggestion above that the 235/35 front matched with 265/30 rear is the best option for Michelin. Although the rolling diameter is about an inch less, and the width 2 inches more (a bit wider than ideal for narrow front rim), the front/rear ratio is constant.
The ideal $ no object solution is to opt for BBS RI-D forged ultralight rims in proper widths.
MKSixer34184.50 |
02-24-2017, 11:32 AM | #15 | |
Rep 244
In anybodies view would it fit on a 7.5"? did some reading about poor handling under extreme cornering |
02-24-2017, 11:53 AM | #16 | |
Rep 83
In autocross, I routinely see people putting tires on that are wider than the recommendation for the wheel width and I haven't seen anyone pop a bead. When it's time for me to replace my tires, I plan to put 245's up front and 275's in the rear. Until then, I won't have any first hand experience to share. |
02-24-2017, 01:45 PM | #17 | |
Rep 244
02-27-2017, 12:16 AM | #18 |
Rep 84
Not to rain on everyone's parade about more grip but Chris Harris' words keep ringing in my head; with wider tires comes less steering feel.
Anyone running the skinny 195 rubber? http://www.roadandtrack.com/new-cars...-chris-harris/ A small, one-word caveat: understeer. For all Munich's talk of balanced weight distribution and a center of gravity just 18 inches off the ground, the front tire choice shows that BMW has been cautious with the i8's fundamental grip. Those tires are a weeny 215-section, and that's only if you choose the optional wide ones. Standard fit is a 195 front on a 20-inch rim. I'd love to see how the handling balance changes on thinner rubber. In most cases, on the optional tires, the i8 gradually pushes its nose wide. Nothing too unpleasant, but it's not that adventurous, either. The narrow paws should bring delicious steering, but with the i8's electrically assisted steering rack—as with most of this type—there's little sense of connection. You never feel blinded by it, but you can't read the road surface through the jingles in your hands, because there are no jingles. |
02-27-2017, 05:41 AM | #19 |
Rep 83
03-17-2017, 02:16 PM | #20 |
Rep 244
Well I had her on a ramp today looking with a body shop at clearances for oversized tyres on stock 7.5/8.5" staggered turbine rims i.e. michellin supersports.
My rears are still legal but I'm not comfortable with such low tread. There are serious clearance issues in the front and rear. without spacers or changing offsets on stock turbines I think it's a risk putting anything but stock Bridgestones. You might be able to squeeze 10mm on the inside but that would be 1-2 mm away from suspension components, body work etc Please someone convince me I'm wrong? |
03-18-2017, 08:49 PM | #21 | |
Rep 11,637
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
03-19-2017, 03:16 AM | #22 | |
Rep 244
Can you give me the specific tyre size/ make and brand please (just want to be double sure we are talking about MPSS's)? How do they look as far as sidewall bulge? Any pics? Thanks in advance Last edited by Mightymousemighty; 03-19-2017 at 06:09 AM.. |
