03-29-2017, 02:44 AM | #1 |
Rep 37
When the battery runs out
When you're driving in comfort mode and the electric battery level runs out and the electric range becomes zero, at that point are you essentially stuck driving from the traditional rear 1.5 litre petrol engine until you either get home and recharge or put it in sport mode to recharge? Sport mode is obviously a much harder drive, and it isn't always preferable to 'have to' put it in Sport mode, if you're in the city in traffic etc.
Only got my i8 yesterday, so apologies for the basic question. |
03-29-2017, 02:52 AM | #2 |
Rep 328
No, comfort mode or eco pro mode will automatically kick the engine in too if the battery level gets too low.
03-29-2017, 02:52 AM | #3 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
I don't think you can run out in Comfort mode. eDrive is the only mode that purely uses the battery. Comfort still uses the ICE, but is obviously much more geared towards efficiency.
03-29-2017, 03:56 AM | #4 |
Rep 37
But right now my battery is empty and I have no way of charging it right now, so if I get in the car and put it in comfort mode, then as there's no battery / electric range available won't it ONLY be using the 1.5 litre petrol engine? Sorry if I'm not making myself clear or if I'm missing something.
03-29-2017, 04:46 AM | #5 | |
Rep 32
If you shift to sport mode then you will still only be rear wheel drive from the ICE but also charging the battery additionally. Once you have some charge in the battery then you have 4 wheel drive again. |
03-29-2017, 05:33 AM | #6 | |
Rep 37
So when you often hear people with i8 say they NEVER charge it, they must be utilising SPORT mode a lot to keep the battery charged, or otherwise they're just driving around using the 1.5 internal combustion engine, which seems a bit odd. Last edited by jonathanthehornet; 03-29-2017 at 05:42 AM.. |
03-29-2017, 06:38 AM | #7 | |
Rep 32
03-29-2017, 07:23 AM | #8 | |
Rep 37
Have you tried using a charger at a services or supermarket yet, I haven't. I assume they are more powerful but someone told me that the i8 will still only support the lower charging rate, so it would take the same amount of time as a standard home charge (3 hours) to fully charge whether it's a more powerful public charger or not. Is that your experience too? 🤔 |
03-29-2017, 07:35 AM | #9 | |
Rep 32
I only opted for the 32A charger to future-proof myself due to available grants at the time. |
03-29-2017, 04:23 PM | #10 |
Rep 174
Re: 'If you shift to sport mode then you will still only be rear wheel drive from the ICE but also charging the battery additionally. Once you have some charge in the battery then you have 4 wheel drive again'.
Don't think this statement is correct. Sport mode engages front wheels instantaneously AND charges the battery, as the engine (in sport mode) generates more than enough to feed both the battery and the motors. So when you are at zero battery, you either drive in comfort and have the engine constantly kicking in and out - a bit uncouth in slow city traffic, or put it in sport - still uncouth in slow city traffic. Therefore best to plan ahead and charge accordingly ;-) |
03-30-2017, 05:19 AM | #11 | |
Rep 32
It is not fair to say that the engine has enough power to feed the battery and motors. The ICE is 231hp and the electric motor approx. 130hp. That means if the ICE is providing 130hp via the front wheels (whether directly or indirectly via charging the battery) then you only have 100hp for the rear wheels. Therefore if you drive in a situation with the battery depleted and drive in a manner that requires more than 230 hp then you will not charge the battery or you will have reduced power available to the rear wheels. |
03-30-2017, 10:34 AM | #12 |
Rep 407
Interesting discussion.
First thing on the original question, tick the box for "Hold Charge", this will use the ICE to charge the battery but at a reduced rate compared to sports. Secondly, will you have front-drive e-power with a range of "0"? I think so. When the battery range shows "0", it does still have some capacity (I think it's really 40% actual capacity). I believe this is to reduce battery wear and also ensures you have 4-wheel drive. The power output from the front axle is reduced but the ICE should be helping by feeding some juice to the battery/motor. Thirdly, using "sport" mode to charge the battery is an expensive way to do it based on European prices for petrol/gasoline!! Much cheaper to plug it in at every opportunity.
2014 i8
2002 x5 4.6is |
zagaboo67.50 |
03-30-2017, 11:46 AM | #13 |
Rep 174
Agree with NGR. You don't get 'Full Beans' but pretty sure you do get 4wd in Sport at 0% battery. 'Spare' capacity in the battery a good, possible explanation!
03-30-2017, 12:05 PM | #14 | |
Driver
301
Rep 382
- The car's Charger (that's the electronics inside the car that control how much power to put into the batteries at various states of charge) - The Charging Station (that's the electronics outside the car) For example, the i8's Charger has only half the capacity of the i3's charger. Since the i8 has a smaller battery, it didn't make sense to put a more expensive, heavier charger into the car. It doesn't matter if your Charging Station is 32A, 40A, or 80A if the car's charger won't make use of any more than 16A. Think of like the Charger as a 60W Light Bulb. It won't use more any more power connected to a 15Amp Circuit Breaker than if it were connected to a 40Amp Circuit Breaker.
03-31-2017, 03:04 AM | #15 | |
Rep 407
Lithium batteries basically wear out quicker if you discharge and charge them fully so the car tells you it's 0% or 100% when it reality it's more like 40% and 90% - it is lying to you! The Battery will still wear out (but slower) and the computer I presume will allow more of the 'hidden' capacity to be used hiding the fact that it's wearing out! Plus it can dip into reserve when you're at "0%", run the aircon/heater etc... - it won't give you the full beans on the front axle to avoid stress on the battery. I once drove mine in electric only, got the range down to "0", then to "-", the computer said 0% battery and the ICE fired up but very much reduced power from the ICE to the rear wheels (if any) it could have still been front wheel drive with the ICE feeding the battery only. I imagine this is how the i3 REX feels when you've gone flat.
2014 i8
2002 x5 4.6is |
03-31-2017, 04:30 PM | #16 |
Rep 7
I have "hold state of charge" set to button 2 on the assignable button array. If I see the charge getting below, say, 5 miles, I'll hit 2 and then engine ensures I've always got at least a little bit of juice in the battery. Enough to get me through most stop/start traffic.
Also, I don't live in a city so I'm luckily never that far away from an opportunity to blat the car in sport mode for a bit to get the charge up, which it seems to do relatively quickly. I've also found that freewheeling down hill in purely electric mode charges the battery quite well. I'll get am extra mile or two that way without covering much distance, it seems to be to do with speed from what I've experienced. |
03-31-2017, 05:01 PM | #17 |
967
Rep 1,723
In the U.S. the battery is 7.1 kWh but we can only access 5.2 kWh. When the battery has 1.9 kWh left we are told it has 0 and the ICE starts. So here when the battery reads empty we still have an inaccessible 25%+ charge. While I suspect it's the same WW I cannot be sure.
When the i8 was first being advertised, BMW was claiming it could go over 25 miles on electric power alone on one charge. Of course, that's because someone in the advertising department was multiplying usage by the total capacity of the battery, not the usable capacity. BMW quietly changed the advertising, but not before a lot of people (including yours truly) had put in our orders. The most I've ever gotten from the battery alone is 21.7 miles. Twice. I drove as if there was a raw egg between my shoe and the accelerator pedal, slowly crept up to the speed limits and tried to avoid red lights and stop signs. With the windows closed and no air con. No fun.
ChiTownM1062.00 |
03-31-2017, 06:29 PM | #18 | |
Rep 174
04-01-2017, 01:22 AM | #19 |
Quadrex
1093
Rep 1,424
I like Comfort Mode more than Sport Mode .When I run out of electric power , I don't shout powwweeererrrr to get them to recharge .I just keep driving in Comfort Mode because Boost is still available if needed some extra thrust .
Sport Mode is quickly charging but it's not the most efficient way of topping up the batteries when they're empty at all
