02-04-2016, 11:48 AM | #1 |
Rep 176
Drives: i3S, iX on order due Nov
Engine mounting bolt recall
My dealer advised that i3's require a bolt changed in the motor mountings plus software change.
It appears that if an i3 becomes airborne and under power the wheels spin up and on landing this puts stress on the motor mountings. I think the software change is probably to restrict the spin up of the wheels in such a situation. It is probably a San Francisco owner doing a Steve McQueen stunt that found the weakness |
02-04-2016, 12:41 PM | #2 | |
Rep 2,736
02-04-2016, 01:12 PM | #3 | |
Rep 2,561
My software version went from I01-15-07-502 to I01-15-11-502. Not sure how much good it really does, as the REX engine mounts seam to be the consistent weak point. A new bolt is the step in the right direction. Upgraded engine mounts may be the ultimate answer, but its sounds like we are a few recalls away from that ;-). a
'19 TM3P (BK/BK)
02-04-2016, 05:35 PM | #4 | ||
Rep 2,736
If it's the Rex only then I don't need to worry. |
02-04-2016, 07:30 PM | #5 | |
Rep 959
02-05-2016, 12:47 AM | #6 | ||
Rep 2,561
What's the full version #? BMW seams to be rolling updates out in a 6-month cycle (May & November), and follows the version number naming convention of I01-YY-MM-502. Here is the November'15 software update TSB: http://cdn.bmwblog.com/wp-content/up...e-november.jpg a
'19 TM3P (BK/BK)
02-05-2016, 04:09 AM | #7 | |
Rep 959
02-05-2016, 09:19 PM | #8 | |
Rep 2,561
You can see how REX engine is mounted on top of electric motors, and the entire assembly moves a LOT. Additional weight of the REX engine can not help but exacerbated the stresses on the engine mounts, so it's a contributing factor to their wear and tear. What I don't know is whether REX and BEV engines use the same engine mounts, or if REX ones are beefed up a bit (clearly not enough). So far, the early engine mount failures have mostly been showing up on REX cars. But with that much lateral movement, it's only a function of time before they age, crack, and break on both types of cars. a
'19 TM3P (BK/BK)
02-05-2016, 10:18 PM | #9 | ||
Rep 2,736
02-07-2016, 10:45 PM | #10 |
Rep 329
I think it happened to my Rex today. Drivetrain malfunction message and then clunking noise from the rear of the car on acceleration, deceleration and turning. Getting it towed to the dealer tomorrow.
Garage:
2014 M6 2015 i3 |
02-08-2016, 08:53 PM | #11 |
Rep 959
02-09-2016, 08:11 AM | #12 | |
Rep 660
02-10-2016, 11:24 AM | #13 |
Rep 2,218
BEV's, although less common, have also had engine mount failures.
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17- - 2015 CPO i01 BEV Laurel Grey Tera World, '17- - 2015 i01 REx Laurel Grey Tera World, '15-'17 - 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15 |
02-11-2016, 09:47 AM | #14 |
Nuclear Chief of the Watch
120
Rep 637
Had the recall done last week and got the upgrade to the display (adds % and some power indicators) - from what I read the BEV gets one bolt changed and the REX gets two.
BMW i3 (BEV) 2014. . Capparis White. . Park Assist, Comfort Access, Enhanced USB
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 |
02-12-2016, 12:37 PM | #15 |
Rep 176
02-13-2016, 12:05 PM | #16 | |
Rep 2,561
Dropped my car off at the dealer for renewed rear suspension clunk, they claimed ignorance of any recalls or TSBs for my VIN. Does anyone know the TSB / notice # for engine mount bolts? TIA, a P.S.: Asked them not to touch the programming this time. I grew tired of reprogramming the car after each and every non-essential software bug fix.
'19 TM3P (BK/BK)
02-14-2016, 03:19 PM | #17 |
120
Rep 637
Drop off at 9 picked up at 4....
02-15-2016, 06:41 AM | #18 | |
Rep 329
Garage:
2014 M6 2015 i3 |
02-16-2016, 10:15 PM | #19 |
Rep 329
Dealer called today that transmission was damaged as well. They will be replacing the transmission and the rear axle.
Garage:
2014 M6 2015 i3 |
02-17-2016, 08:26 AM | #20 | |
Rep 2,561
Did you go airborne or off-roading or something? If yes, don't answer ;-) a
'19 TM3P (BK/BK)
02-17-2016, 09:05 AM | #21 | |
Rep 329
Garage:
2014 M6 2015 i3 |
02-17-2016, 11:11 AM | #22 | ||
Rep 2,736
Crazy cheap! Engine is like $1500 That's all without the 20% off discount ! Can't believe their so cheap. Just the batteries you have to worry about as those are the guys that carry the cost! |
