06-25-2016, 11:19 AM | #1 |
Rep 503
Center stack lighting outage
Has anyone else had this center stack flicker, then go out??
It came back on after powering down then back on . Have an appointment today, will report findings for future reference. |
06-26-2016, 10:31 AM | #2 | |
Rep 2,561
What exactly are you referring to as "center stack"?
The HVAC buttons cluster? Quote:
I took the car in for service, and after replacing the actual seat heating elements in vain, the dealer had to order from Germany and replace the "Radio and climate control module" #61-31-9-379-125. That fixed the issue for me. a
'19 TM3P (BK/BK)
06-26-2016, 04:12 PM | #3 | ||
Rep 503
A, have you had any check drivetrain notifications? |
06-29-2016, 02:14 PM | #4 |
Rep 2,561
Actually, yes, I did. Not sure if it was related though.
My i3 is a semi-lemon, managing multiple issues going on at the same time, most of the time. a
'19 TM3P (BK/BK)
06-29-2016, 02:37 PM | #5 | |
Rep 503
Would you mind sharing the issues you are experiencing ? Via PM or email if you prefer. I too have been concerned about my i3. Like other underlying issues may be present. |
07-02-2016, 09:59 AM | #6 |
Rep 503
In case anyone was curious as to what the results of taking my i3 to service was :
It was a result of low voltage. In my experience thus far with the i3, I couldn't personally chalk up low voltage to be the cause. I've ran purely on the range extender a few times when the battery was less than 5% and have never had this problem. Here in Texas, I'm wondering if this heat was part of the problem. |
07-03-2016, 07:49 PM | #7 | |
Rep 2,736
07-04-2016, 10:51 AM | #8 | |
Rep 2,561
I do believe that I got a lemon-ish i3 (Nov'14 build), as others have reported minimal to zero issues with theirs. Over ~16 months and 17K miles of ownership, my car has been in for warranty work at least 8 times. 3 repairs had to wait for parts from Germany that took more than a week to arrive and get installed. In total, I had put ~3K miles on the loaner BEV (roughly 1/3 of total miles on that particular loaner ;-). On the plus side, driving the loaner does help with my lease mileage quota, though. So far, I've had the following things worked on / replaced / reprogrammed, some multiple times: - engine mounts and bolts (3 times to date - kid you not). Temporary improvement after each attempted repair, squeaking persists. Worst when freezing outside - to be continued in December (SIB 220415, RO 374684). - steering column squeaking / clunking / rattling (multiple times). Things lubed and replaced (SIB 320315, 310614, 320415). - right rear suspension (shock replaced, bolts/mounts/pads replaced). Clunking persists (SIB 220115). - seat heaters failed. Seat heating mat replaced, radio and climate control unit replaced. - check engine light on (multiple). Replaced "battery charger isolation valve". Replaced A/C charge lock actuator(?). - "lighting system malfunction", "chassis stabilization malfunction". Can't be reproduced, things reprogramed, repeat. The above are from memory and some receipts I filed away. YMMV, a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 07-06-2016 at 08:29 AM.. |
07-04-2016, 10:54 AM | #9 | ||
Rep 2,561
When I lived in TX, all 12V batteries lasted half of their expected lifespan in the rest of the country, and usually failed in the summer. Has anyone looked - is i3's 12V battery fully sealed and maintenance free, or do you have to add distilled water to it? a
'19 TM3P (BK/BK)
07-05-2016, 08:15 AM | #10 | |
Rep 660
