      04-21-2016, 10:52 PM   #1
askmeaboutkfc
Drives: 640i
cigarette lighter
The cigarette lighter is so shallow. I am not able to put a charger and a cord without leaving the center console open. I am using a tiny charger and an angled usb cord. But still the center console will not close. Do you guys have any ideas?
      04-23-2016, 12:31 AM   #2
mptpa
mptpa's Avatar
Drives: 2019 M850i
Are you trying to charge your phone through USB? Why not connect directly to the USB port in the middle console? That is what I do.
2019 M850i (ED Mar 2019) Sonic Speed Blue/Fiona Red/Black
2018 X4 M4.0 blue/white (wife?s)
2015 i8 (Feb 2016) White Pure Impulse (SOLD)
2015 M4 (ED Aug 2014) Austin Yellow/Sakhir Orange, EXEC, DCT, LED, Driver Assist (SOLD)
2015 328GT (ED Apr 15), White, loaded (Wife's)
2012 X3 2.8, Dark Blue/Red (Wife's SOLD)
Retired: 2011 535i, ED / 2008 335is / 2006 525i ED,
2003 525i ED / 2002 Audi TT
      04-23-2016, 12:39 AM   #3
Nick8112
There is a cigarette lighter under the glove box on the passenger footwell. Thats where I plug my charger in. It's hidden but roughly above the left knee
      04-23-2016, 12:40 PM   #4
PurplePeril
PurplePeril's Avatar
10
Drives: i8 & 458 Italia
Use the other usb outlet in the compartment to the front of the one with the lighter socket in?
      04-23-2016, 01:04 PM   #5
jhbi8
jhbi8's Avatar
47
This is what I do for my radar detector.
There's an adapter for the center console for your phone charger. The dealership will have a couple of different kinds.
2015 BMW i8 | 2011 Twin Turbo 1250hp Lamborghini Performante by Underground Racing
      11-15-2018, 05:28 PM   #6
hotwire73
Drives: i8
Anyone find a power adapter for the center console that allows it to be shut. I have radar detectors, and dvr cameras on my dash, need to power them. Doesn't seem either one of these turn off when switched off, seems all time power.
      11-19-2018, 01:36 PM   #7
evanevery
evanevery's Avatar
1113
Drives: iXM60, i8 Rdstr, M4, i7 M70
The USB ports don't provide enough power. You will need an ACC port and a dedicated USB charger for a full 2.4A of usb charging power.
I've tried all of these options below and they all fit/work in the i8 Console with the cover closed. (Its a stupid design)
Get a low profile USB charger:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And use a USB charging cable (M-F) with an angled head:
..or a 90 degree USB adapter:
      11-25-2018, 02:08 PM   #8
rastaman777
Drives: 2020 i8 coupe,2019x5,2019 740i
Ditto to above.
I'm using the dual usb cigarette adapter, with two right angled usb/lightning cables. Console door closes without any problem.
      11-25-2018, 02:09 PM   #9
rastaman777
I"ve got both as well - hardwired.
Much cleaner look that way, not that hard to do if doing it yourself, or should not be too much $ to get someone to do it.
      11-25-2018, 03:40 PM   #10
M8INLA
M8INLA's Avatar
Drives: 2020 BMW M8 Competition
I connected my escort 360 & M1 dash cam through a mirror tap. was super easy to do and no cables hang down. looks super clean! it all shuts off when the car is turned off.
https://www.blendmount.com/mirrortap.html
      11-26-2018, 01:23 PM   #11
evanevery
evanevery's Avatar
1113
Radar detectors and dvr cameras (specifically) don't lend themselves well to be powered from the console port. If you want to power those type of more "permanent" things, its better and much cleaner to use a micro-fuse tap right from your fuse box. There are even a couple of fuse slots completely empty (You can use the microtap on fuse slots which are empty or in use). You can also select fuse slots that are only powered when the car is running (aux). No splicing or soldering required! Just pop it in!
The fuse box only requires unscrewing TWO screws and its easily accessible (right under the glove box). Then you can run your wiring up the A-Pillar right behind the trim and rubber door seals. No need to remove any trim panels, just tuck it in...
Here is the micro-fuse tap: https://www.amazon.com/10-Pack-Add-c...de+Fuse+Holder
      03-30-2021, 06:46 PM   #12
MGRMLN
Drives: 2015 Nissan GT-R Black Edition
switched 12V socket?
Are any of these sockets switched or always on?
2019 Volcano Orange McLaren 570S Spider
2019 Carrara White Porsche Cayenne
