      01-27-2021, 02:00 AM   #1
MolarBear
Drives: BMW i8 LCI
Boot / Trunk not closing in low temperatures?
Has anyone had it where the boot won't click/close fully at low temperatures of around 0/-1 degrees? This week I was unable to close my boot fully - it would do the first click to engage but I was unable to close it fully to the second click - so I was driving around with the boot open message on the screen. Once warmed up I managed to close it without issue.
Should it work if it goes below freezing? Kind of a problem if it doesn't! Unsure if it's just mine or a common issue? Also had it where the boot won't open at all at low temperatures as the spring/plastic barrel in the boot pin freezes and gets stuck and doesn't release!
      01-27-2021, 06:31 AM   #2
Leto1701
Leto1701's Avatar
64
Short answer, no, didn't have the issue and no, this is not normal and shouldn't happen. Maybe moisture trapped somewhere in the mechanism? Car parked in the open somewhere?
      01-27-2021, 03:44 PM   #3
Ionicsilveri8
Drives: Donington grey i8 LCI
Didn’t you have an issue with the rear latch when you bought the car? There was a plastic plate missing? Maybe connected?
      01-27-2021, 05:18 PM   #4
MolarBear
Drives: BMW i8 LCI
Originally it was a broken boot pin that was replaced by the dealer. This has only happened now when it went to minus figures - might need to ask the dealer! Thanks!
Leto - Thanks! will check with dealer.
      01-28-2021, 08:23 AM   #5
Iain123
Drives: I8
I've had to stretch the spring on mine to get the boot to pop up enough for my fingers.
Yours may just need a bit of grease. Its just a simple plunger with a spring inside held on by a couple of screws. Make sure its not come loose and add some lub maybe?
      01-28-2021, 10:52 AM   #6
MolarBear
Drives: BMW i8 LCI
Thanks. It's not the plunger I believe - I think it's the electronic claw that's not fully engaging at cold temps. It clicks to first level but not the second level so it's in enough to hold it but not in enough for the car to be happy!
