      02-02-2017, 03:54 PM   #1
Untdrums
Untdrums's Avatar
Drives: '18 440i GC, '15 i3 REX
It is bad to leave Fuel in the Tank?
Hello All,
I recently had my car coded this past weekend for a number of things and have been wondering this question for a while.
How often is it necessary to make sure you use the fuel in the gas tank? My daily work commute is ~55 miles a day round trip and I don't need to set the REX to kick in before I can charge it again. Thus, I hardly ever use the REX unless it's the weekend.
Thanks,
Josh
2019 CW i3s BEV
2018 EB 440i Gran Coupe
2015 SO i3 REX *lease return
2015 EB M235i Euro Delivery 11/26/2014 *lease return
2014 MG X1 sDrive 28i MSport *lease return
2011 BS 335d *sold
      02-02-2017, 04:33 PM   #2
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
not knowledgeable in this, however the Chevrolet volt is programmed to burn the gas every so often to keep it from going bad. I'm sure bmw thought of this as well
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      02-02-2017, 08:47 PM   #3
MalibuBimmer
MalibuBimmer's Avatar
2018 Mercedes AMG GT  [0.00]
2018 Audi Q3  [0.00]
2015 BMW M4  [10.00]
More to protect the engine from inactivity. Same with the i8.
The gasoline will deteriorate and lose octane count over time but it would take years for it to go really bad.
I run the ICE every once in a while and burn the fuel down to 1/4 tank. I realize that with the REX you can't do that unless you run down the battery. Nevertheless, I wouldn't worry about it.
      02-02-2017, 10:10 PM   #4
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
It will run a maintenance cycle by itself after about 6 weeks of non use.
I haven't used my REx for only about one month so far.
Before I was playing around with it trying to gauge the mpg on the REx.
I only have mine for about 2 months now.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      02-02-2017, 10:11 PM   #5
r33_RGSport
You can code it to allow you manually run the engine. But you have to be at 75% battery SOC to start the engine.
      02-03-2017, 03:27 AM   #6
bailyhill
Drives: '20 X3 30e
Coding
Hello
About to take over a lease on an i3 REX and am not familiar with the coding thing. Is this something the dealers will do or not? Suspect changing the point where the REX can be turned on affects emissions and would not expect a dealer to do it. Does it affect your warrantee from BMW if you have an outside shop do it? I gather that when you have your car serviced, they may flash everything back to baseline unless you ask them not to. Your experience would be helpful.
Bailyhill
Current: "17 i3 REX; X3 30e
History: '67 911S, '72 MB 280 SE 4.5; '74 2002, E21 ('78 320i, E28 ('85 535i) , E36 ('90 325i), 6 Volvos; '14 ForTwo eDrive; '15 i3 REX, F31--'15 328 D Sportwagen; F25 LCI '16 X3 D
      02-03-2017, 09:04 AM   #7
r33_RGSport
Originally Posted by bailyhill View Post
Hello
Bailyhill
Most dealer won't do it.
You can find someone local or I can do it remotely.
You just need a Windows laptop, ENET Cable, and the softwares.
It doesn't void a warranty since you are just turning on an option that is available in the car all along.
But, dealer may reset it if they have to update some firmware in the car.
