05-23-2015, 08:22 AM | #1 |
Rep 664
Charging for Beginners
Hi everyone,
I've been contemplating an i3 and my local dealer was kind enough to let me borrow one for the day. Being completely new to the EV world, I have a few basic questions regarding charging: They gave me a charging cable that plugs into a standard 3-prong outlet. If I leave it plugged in overnight will it continue to draw electricity/overcharge the battery or does it cut off power at 100%? I don't want to be wasting electricity. Also, I read online that you can use an app to show % of battery. Is this worth using? If I'm missing anything I should know please advise. Thanks in advance, Ryan |
05-23-2015, 08:54 AM | #2 | |
Rep 2,736
You need to own the car to use the app. At least I think. |
05-23-2015, 11:54 AM | #3 | ||
Rep 2,561
Car can be programmed to pre-heat/cool before departure while still plugged in, but that's an optional feature. However, with the loaner 120V cable, you will be lucky to achieve full charge overnight. It takes ~20 hours to go from 0 to 100% using Level-1 120V charger. Basically, 120V charging is for emergencies only, and can't be relied on for daily use. If you have to rely on your i3 loaner for multiple days, you will need to find a local ChargePoint.com charging station and payup for faster Level-2 240V charging access (download the app!) Quote:
That app on-boarding process is not available for dealer loaner vehicles. a
'19 TM3P (BK/BK)
05-23-2015, 06:55 PM | #4 |
Rep 1,061
The car's internal logic automatically maintains a safety buffer in the battery charge at both the top and the bottom, meaning, it won't let you overcharge or deplete the batteries which makes them last much longer. WHen it says 100%, it's not really, nor when it says 0%, is the battery actually fully discharged.
05-24-2015, 07:48 AM | #5 | |
Rep 664
05-24-2015, 04:32 PM | #6 |
Rep 2,561
You can buy one for $500-$1000 (higher end covered by BMW's branded Schneider unit).
Installation will vary depending on location's layout and logistics (need at least 40 Amp circuit, plug vs. hard wiring, etc). I had re-used the electrical drier plug and wiring in my house, to installation was ~30 minutes of DIY labor. a
'19 TM3P (BK/BK)
