01-20-2023, 07:45 PM | #1 |
Rep 5,796
Drives: 2024 BMW XM Label
BimmerCode Update
The newest BimmerCode update now supports the i4. Unfortunately for us, the iX was not included in the update. Not sure what modules are actually accessible. I know it’s very limited.
01-20-2023, 08:02 PM | #3 |
Rep 5,796
It’s basically an electrified 4-Series Gran Coupe. Of course it’s running iDrive 8 which is a completely different system. BMW has really locked the modules down. Most of the modules can only get the configuration changes from BMW now. Whatever coding changes are possible will be very limited by comparison to any previous iDrive system.
01-20-2023, 08:26 PM | #4 |
Rep 1,833
Drives: BMW iX Xdrive40 MSport
See my sticky on IX coding here: https://bmwi.bimmerpost.com/forums/s....php?t=1965217
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
VirtualGuitars7869.50 |
01-20-2023, 08:48 PM | #5 | |
Rep 5,796
01-20-2023, 08:51 PM | #6 |
Rep 1,833
I4 is an SP18 car so most of the coding possible on the 4-series should work.
01-20-2023, 08:52 PM | #7 |
Rep 5,796
01-20-2023, 09:01 PM | #8 |
Rep 1,833
iDrive 8 is only one part of the car, and the regular 3 and 4 series have it now too. Depends on what type of coding you are talking about. Video in motion and nag screen disabling? Yes, all possible on ID. The way you access the coding data and deploy it to the car has not changed for iDrive. It's every other module on the SP21 cars that cannot be coded because the requisite coding files are not available.
VirtualGuitars7869.50 deutsch1004085.50 |
01-20-2023, 09:05 PM | #9 | |
Rep 5,796
ricerboi905.00 deutsch1004085.50 |
01-21-2023, 09:03 AM | #10 |
Rep 39
VirtualGuitars
What model OBD2 scanner are you using? I am new to this and would like to check out what it does. Also, is there free software that can be used (or buy with 1time fee). Appreciate if somebody can post the links for HW/SW. |
01-21-2023, 09:06 AM | #11 | |
Rep 5,796
https://www.bimmercode.app/adapters/ BimmerCode is worth every penny. If you don’t know what you’re doing, this app makes it really simple and is worth the $20. The same link above. Just know that if something gets messed up, it does create a backup for each change. You may run into warranty issues if you have problems with something you may have modified. Just know that in advance. Also note that anytime there’s a BMW iDrive software update it usually wipes out any custom coding you may have done so you may have to redo it. Not a big deal. Some advanced coding requires an actual ENET cable, but it also requires hacked BMW software. With all of that being said, iX is not supported with BimmerCode yet anyway. |
01-26-2023, 06:35 PM | #12 |
Rep 13
Basic Coding for iX popping up on Websites
It appears the basic coding mods are slowly making their way to the various coding websites. This is the first one I've noticed that's updated to reflect iX as compatible. Does anyone know if buying tokens for the iX is reliable right now to code for VIM, delete saftey warning, etc? I'm a bit skeptical given we are still in the early days.
website link: https://obdeleven.com/en/supported-vehicles?brand=bmw |
01-26-2023, 06:37 PM | #13 | |
Rep 5,796
01-26-2023, 06:37 PM | #14 |
Rep 13
the i4 is now on bimmercode as of sev days ago
01-26-2023, 06:38 PM | #15 |
Rep 5,796
01-26-2023, 06:45 PM | #16 |
Rep 13
thanks, that's really helpful. I view BC as most reliable source out there and will take them at their word. For what it's worth, the description for iX VIM on OBD website is rather confusing. Initially describes as VIM for PASSENGER, then later says video WILL LOCK when car moves. So honestly who knows... Will avoid until more clarity is received.
01-26-2023, 06:47 PM | #17 |
Rep 13
sorry i misread that, long day in traffic...
01-26-2023, 06:48 PM | #18 | |
Rep 5,796
01-26-2023, 06:57 PM | #19 |
Rep 13
thanks - yes i have that bookmarked and followed. haha - i'm very keen on monitoring the developments of this! but sadly, will keep my expectations tempered given the new 'gate keeper' process that BMW is likely using for future subscriptions....
01-26-2023, 06:59 PM | #20 | |
Rep 5,796
iX_Los Angeles25.50 |
01-26-2023, 07:00 PM | #21 |
Rep 13
01-26-2023, 07:30 PM | #22 |
Rep 1,833
I will give VIM another go this weekend. I found some additional parameters related to the speedlock in the MGU CAF file. I'll report back after testing.
VirtualGuitars7869.50 jolaca24.00 |
