08-31-2015, 09:48 PM | #1 |
Rep 2
Coding door lock doesn't work
I really dislike that every time I drive that the door locks engage since when I get out of the car and want to\ get something out of the passenger side I have to unlock the door.
Using the coding guides I tried to use this programming setting to disable that behavior: Disable Auto-Locking of Doors once begin driving 3000DOOR_LOCK_AFTER_DRIVING_AWAY set to: nicht_aktiv But that setting was already set to nicht_aktiv so I am stumped as to how to disable that functionality, Is there a better setting that fixes this on the i3? Thanks, Rick |
07-16-2016, 06:35 PM | #2 | |
Rep 2,561
To disable automatic door and hatch lock after you start driving: BDC Body Module: 3040 : VAM_SPEED_LIMIT_ PIA_AUTO_LOCK set to: werte = FF a
'19 TM3P (BK/BK)
07-19-2016, 02:30 PM | #3 | |
Rep 2,736
07-20-2016, 09:30 AM | #4 | |
Rep 2,561
Give it a try!
'19 TM3P (BK/BK)
07-20-2016, 03:52 PM | #5 | |
Rep 2,736
Figured the i3 was the same. Since I have comfort access I never had an issue as the door would always open. So I never went to play with options in settings to see if it where their. |
07-20-2016, 09:21 PM | #6 | |
Rep 2,561
This is also a problem, though less frequent, even if you DO have comfort access and have someone else other than the person with the key attempt to extract the groceries from the trunk. In fact, it was this very same PITA that drove me to learn how to code the car All the iDrive UI allows one to do is adjust what happens when you press the physical "lock/unlock" button (page 45): https://cache.bmwusa.com/PDF_9752ed5...2-6cd02d8b5b74 The car still auto-locks when you drive away, unless you code it to your liking. a
'19 TM3P (BK/BK)
07-23-2016, 11:30 AM | #7 |
Nuclear Chief of the Watch
120
Rep 637
I think it is based on being an "urban" car and hence "extra" secure - we have comfort access so is not an issue for us. -
Comfort access does work if you have the key and touch the person opening the door or boot - spooky but fun.
BMW i3 (BEV) 2014. . Capparis White. . Park Assist, Comfort Access, Enhanced USB
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 |
07-23-2016, 01:10 PM | #8 | |
Rep 2,561
?? Didn't realize things went south THAT fast post-Brexit... a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 07-23-2016 at 01:17 PM.. |
07-28-2016, 12:01 PM | #10 | |
Rep 2,561
I coded auto-unlock to "aktiv", but it wasn't unlocked the car upon parking. The only thing that did the trick for me (on the latest firmware) was to set auto-lock to kick it at speed threshold of "FF" (aka 255 km/h). a
'19 TM3P (BK/BK)
