03-26-2020, 12:57 AM | #1 |
Rep 11
Best tire option for i8?
So far I've seen people using mainly Michelin Pilot Sport 4s and Pirelli P Zeros.
Which tires have been lasting you the longest while providing a great ride? I need something that can handle turns on canyon roads with ease. I drive in Southern California weather 90% of the time so snow isn't an issue. I'm also debating on getting wider tires. I've seen a lot of you guys getting 245/40R20 and 275/35R20. Someone pointed out that wider tires could be an issue for the aerodynamics though. Have you guys experienced many cons with wider tires? I also saw someone opt for 245/40/20 front and 255/40/20 rear which looked like a good combo too. |
03-26-2020, 09:47 AM | #3 |
Rep 309
Well.... that’s one opinion.
I installed Bridgestone 245’s and 275’s on the stock rims and I think the car looks much better and handles way better. The original skinny tire sizes in my opinion look dumb on the car. I have absolutely no clearance issues. As far as aerodynamics or increased rolling resistance affecting your gas mileage, for me it’s not measurable in normal driving. |
03-26-2020, 11:18 AM | #4 | ||
Rep 451
My only hesitation to changing the tires is for aerodynamics/handling. Is occasionally but regularly going 140-150mph considered normal driving ? I'm sure it can't be a big deal not using stock tires. |
03-26-2020, 01:31 PM | #5 |
Rep 52
In my corner of the wold(Europe) it’s simply not legal to use tyres with different dimensions than is stated in the COC. In Norway we have to pay additional tax when opting for wider/bigger wheels as the Co2 emission increase and our tax system is based on the cars co2.
03-26-2020, 05:48 PM | #6 |
patsgarageonline.com
101
Rep 170
I'm running 30mm wider (and 5% lower profile) all the way around. I chose an all season tire for better traction in all weather conditions, since I daily drive my i8. I did a review of these tires after 10k miles and compared them to the original tires which also had 10k miles on them.
03-28-2020, 12:43 PM | #7 |
Rep 94
I also run all seasons on my i8 since it's my daily driver throughout the year. I run a 245 square setup, Bridgestone RE980AS that totally eliminates the skinny front tire induced UNDERSTEER but doesn't introduce the additional friction drag of 275's at the rear. No rubbing issues at all.
I did swap my factory lug bolts with titanium ones that helped lower unsprung mass.
2019 Volcano Orange McLaren 570S Spider 2019 Carrara White Porsche Cayenne |
03-29-2020, 11:47 AM | #8 | |
Rep 18
245/40x20 and 275/35x20? Thank you. |
03-29-2020, 11:53 AM | #9 | |
Rep 10,858
Thanks, I am an unsprung weight reduction junkie... And if anyone knows a source to get the stock all black 516 rims I would be most thankful. Or BBS FI-R. My recommendation is Michelin Pilot sport 4S, unless a) you want stock size, or b) live in NW or other rainy place; in which cases I suggest the Pirelli P-Zero. My choice for now is Michelin PS 4S 20 235/40 and 265/35
04-01-2020, 09:48 PM | #10 | |
Rep 94
Bought them here: https://smile.amazon.com/gp/product/...3400_397493790
04-02-2020, 10:10 AM | #11 | |
Rep 309
They fit just fine on the stock wheels with no clearance issues. Adds 30mm in width with the tire diameter and sidewall dimensions remaining almost identical to the original BMW tire choice. |
04-02-2020, 10:22 AM | #12 | |
Rep 309
I’m not sure that’s normal driving or responsable driving but the speed ratings on the tires are the same as the original tires and with proper tire pressure I can’t see a problem. |
04-03-2020, 10:15 AM | #13 | |
Rep 10,858
04-04-2020, 09:25 PM | #14 |
Rep 94
Yes! That's exactly why I got them. I'm running 245 square setup with 3mm spacers so I wanted to offset the gains. I think the combo is still lighter than box stock.
06-09-2020, 08:14 PM | #15 |
Rep 10,858
I am about to pull the trigger on a set of Michelin PS 4S 245/35 front, 275/30 rear. a bit smaller diameter but should be OK. Any thoughts on these sizes?
06-09-2020, 11:27 PM | #16 |
Rep 13
I run PS4 235/45/20 front and 265/40/20 rear on stock rims, perfect rolling diameter match and slightly taller gearing, same 0- 60 times but a little less snappy off the mark (keeps the wife from complaining ) nice ride on not so good roads here in Thailand.
also fills the wheel arches nicely, no spacers needed, has 5mm clearance to front upright, ride height increase about 5mm this set done 18,000ks and look to still have 80% whereas Pirellis were stuffed at 15,000 Last edited by jezza211; 06-09-2020 at 11:49 PM.. Reason: more info |
07-21-2022, 06:43 AM | #17 | |
Rep 3
245 all around, Got it. You mention 3mm spacers? Is that on all 4 or just the front? Thanks. |
01-22-2023, 03:52 AM | #18 | |
Rep 75
I’m debating this or a 245 on each corner. Both look viable, but I can’t see if any spacers out other adjustments are required? Many thanks |
