04-11-2018, 10:43 PM | #1 |
Rep 11
Level 2 Charging Time
I've had the i3 two weeks now and wanted to check out the Rex operation. So, i didn't charge it for a few days so that the Rex came on. I drove it to the office and back on the Rex and everything seems fine. In the meantime, I've received my TurboCord, had a 240 v. outlet installed, and am ready to check out Level 2 charging. I was expecting a charging time of 4 hours or so, but, instead, it's saying 9.5 hours to fully charge. I found the charge settings and it was set for maximum charge rate. Can anyone make sense of this?
04-12-2018, 10:25 AM | #2 |
Rep 9
What is the amperage of your charger? It needs to be 30 amps to charge in 4 hours. Some level 2 home chargers are 16 amp. Also check the charge level on your home charger if it is programmable.
04-12-2018, 11:06 PM | #3 |
Rep 11
OK, that is helpful. I checked the specs on the TurboCord, and it delivers 16 A. to the car. At 240 V. that's 3.8 kW. If I have about 30 kWh to charge, that would take about 8 hours.
04-13-2018, 09:32 AM | #4 | |
Rep 2,561
a
'19 TM3P (BK/BK)
04-13-2018, 10:45 AM | #5 |
Rep 2,080
L1 charger for the 2017+ I3 is 24-28 hours from 0%. Level 1.5 (as I call it) which is the 16A 240V turbocord and similar, are 8.5-10 hours. Level 2 30A is 4-4.5 hours. 30A is the max the I3 will charge at. If it could accept full level 2 at 40A it would charged in 2.75-3 hours.
04-16-2018, 08:43 PM | #6 |
Rep 11
So, this has been informative. I kind of assumed that a charger that BMW would put it's name on would be the latest thing. But, you've let me know that I could get a 30 A. charger. Now, for any use at home, the 16 A. cord is adequate. It can recharge from zero overnight. So, the only reason I can think of for returning the BMW TurboCord and getting a 30 A. would be for when I'm traveling and find a 30 A. outlet rather than a L2 station and need to charge on the road. Anyone disagree?
04-19-2018, 08:24 AM | #7 | |
Rep 1,078
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
Level 1.5, I like that for the Turbo Cord 20a option. I like many was misled on how quick the Turbo Cord charges. Its fine, if I get another "e" BMW I will probably put in a full L2 30a socket, no big deal I know a lot of electricians. If I didnt have a Rex it maybe be a different story.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
04-19-2018, 09:04 AM | #8 |
Rep 2,080
Good points above. Also it's more costs to run a 40 or 50 amp circuit for the Level 2 vs 20 amp for level 1.5.
And the plugs are different: NEMA 6-20 for the level 1.5 NEMA 14-50 for the level 2 (at least the 40amp level 2 I have). The circuit and breaker need to have 20% more capacity than the max the EVSE will pull by almost all electrical code in the USA and for good reason. |
07-09-2018, 11:23 PM | #9 |
Rep 10
I have a Clipper Creek 24A charger in transit now. With a 30A+ charger you'll need a 40 or 50A line to be aligned with code. For wire runs over 15' that means 8AWG Romex wire, which many don't have on typical "dryer" receptacles.
30A line/plug/breaker is fine for a 24A charger, which will easily charge my 2018's 30kw/hr (usable) battery from empty to full overnight. And it will very rarely be empty, since my commute is under 50 miles/day. It's not a lot cheaper to go with 24 vs 30 but something to think about. |
