      09-05-2024, 02:36 PM   #1
tankertoad
Drives: 2000 e46 coupe
Promising battery upgrade (154ah)
https://mtgbattery.com/bmw-i3/
      01-04-2025, 10:14 AM   #2
garretok
Drives: i3 94ah
whats the cost for this?
curious what this costs and also where / how it is done.
      01-05-2025, 02:57 AM   #3
ilivas
Drives: 428
Any news on this?
2014 BMW 428i Stage 1
2014 C7 Corvette Supercharged/Cam/Methanol 786whp
2013 Ducati Streetfighter
      01-05-2025, 06:24 PM   #4
Mondomensch
Drives: 2020 BMW X3 sDrive30i
The specs in the ad don’t really correspond to each other, eg 40kWh to 54kWh but range only goes from 340km to 400km? Also the sizes shown of the individual battery modules are very different from the OEM ones, so how could it be installed, much less be managed by the car’s systems?
Someone had a YouTube video of a Czech car enthusiast interviewing a local i3 guru there who mentioned they do a lot of installing used working battery packs from scrapped cars into working i3s. Something like that is probably a better bet if you are located in Europe.
      04-18-2025, 08:00 AM   #5
H1GhPwR
H1GhPwR's Avatar
Luxembourg
52
Drives: BMW i3 94Ah
Here as well:
https://insideevs.com/news/756933/bm...-pack-upgrade/
On Alibaba, the 154 Ah pack is priced at $5,800 without shipping. There’s also a $4,800 120 Ah version that can be a direct replacement for the original 120 Ah pack. MTG says the new modules come with a three-year warranty and are rated for 2,000 charge and discharge cycles. Whether or not that warranty can be honored in the United States is another topic.
That said, an original, BMW-sourced pack costs around $15,000 without labor. Even if the shipping costs for the Chinese pack are the same as the pack itself, the final check should still be lower than the original.
      05-19-2025, 04:25 AM   #6
respo
Drives: bmw i3
im little bit suspicious about chinese battery upgrade
      05-21-2025, 02:45 AM   #7
H1GhPwR
H1GhPwR's Avatar
Luxembourg
52
Drives: BMW i3 94Ah
99% of all your batteries come out of China
      05-23-2025, 05:49 AM   #8
Nahlem
Nahlem's Avatar
Drives: i3
Interesting if this was combined with Gen6 drivetrain on this lightweight car as is i wonder how good efficiency you would get out of it.
Current Car: Bicycle
      07-05-2025, 03:25 PM   #9
alohart
Drives: 2021 BMW i3
You might want to consider the quality of some of these Chinese battery pack rebuilds.
      08-22-2025, 11:00 AM   #10
jamvont
Drives: BMW i3
Did you try this? Just curious.
      08-28-2025, 10:07 AM   #11
emlai3
Drives: BMW i3
Yes, it would be very interesting to hear from someone that has installed this. If the numbers are correct it would almost double the amp hours of my 94 Ah.... Real nice to be able to get a bit further between charging stops when going on road trips.
