      08-20-2025, 06:15 PM   #1
Dafireman12
Dafireman12's Avatar
Drives: BMW i3
ESYS Help
Getting the following error when calculating for istep . Anyone know how to fix?
      08-21-2025, 03:14 AM   #2
Eternal Vibration
Drives: 2017 M4
Did you get esys from shawnsheridan?
Also go to options/settings and make sure your pszd file location is setup correctly.
I downloaded his files and was able to generate, calculate and flash with his setup. With the exception of having to remove one of the ECU's from the flash list. It works well. My ASCM was failing to calculate so i removed it form the TAL calculation and it worked.
      08-21-2025, 11:53 AM   #3
Dafireman12
Drives: BMW i3
No I didn’t, where do I find the software?
