10-03-2022, 04:46 PM | #1 |
Rep 303
Is ceramic coating worth it?
I started to go down the rabbit hole of cleaning my new iX and the thought of waxing it every three months is very unappealing. Is it worth to spend the money to get the XPEL Fusion Plus ceramic coating? My understanding is that it will make washing the car much easier and it will stay clean longer from each wash. The coating lasts about 4 years?
Is it most common to do paint and wheels? Thanks in advance |
10-03-2022, 04:51 PM | #2 |
Rep 136
I did my 6 series. I kidded myself it made the difference that you describe- mostly it helped avoid swirl marks from rain a little. Maybe the one I did wasn't a v good one, and that's why I was underwhelmed.
10-03-2022, 07:26 PM | #3 |
Rep 4,504
Drives: 2022 iX xDrive50, DGM
Ceramic coating is a great option for the reasons you mention: a good wax job lasts weeks or months, a good CC lasts years - with caveats following. CC does however require detailing and paint correction before application - it's not a "wash and apply" product to see the best results, mainly because it's semi-permanent and you don't want to lock in orange-peel and paint defects after it's applied. That also accounts for much of the cost of a good ceramic detail. And it does require some maintenance - it's not ideally "set and forget." Some finishes need an annual inspection and refresh (Ceramic Pro), and some can stretch the interval between refinishing (XPEL). And it's usually necessary to apply a refresh or detail spray to the coating as well after washing to stretch the recommended reapplication intervals (and individual products have their own formulas). A detailer can also protect the interior and wheels with ceramic, and reduce maintenance there too, especially for leather seats. CC is ideal if you want a nice looking finish without spending weekend hours waxing and polishing, but some like the therapy and "hands-on" of waxing their car - you lose that with CC, because waxing is out once you apply ceramic. No finish is perfect, and each have their uses for a particular application. I've come to favor ceramic because I don't want to spend my free hours washing and waxing, and I have XPEL on my current garage queens, but different strokes. A mini-primer on finishes:
10-03-2022, 07:48 PM | #4 |
Rep 86
Ceramic coat doesn't last very long under uv, so if you park mostly under the sun, it may only last one year which isn't worth it, unless you can get it done very cheap say in Mexico.
10-03-2022, 08:05 PM | #5 |
Rep 4,504
Ceramic formulations are essentially unaffected by UV radiation (A or B), but will offer pretty good protection to the underlying paint and clear coat from UV related oxidation and subsequent fading. CC does very little to filter UV radiation but is very resistant to oxidation, so it protects the clear coat - which does provide UV protection to the base coat underneath - from the (most damaging) oxidizing effects of UV.
10-04-2022, 12:21 AM | #6 | |
Rep 579
Drives: F15 X5 50i, G30 M550i, iX 50i
10-04-2022, 05:57 AM | #8 |
Rep 97
It's good. If you don't want to wash your car after every rain its good. I am pretty particular and end up washing my car about 1/2 as much since after a rain it's still looking 90%.
10-04-2022, 06:55 AM | #9 |
Rep 303
My primary motivation is not having to worry about waxing it or doing anything other than washing it.
10-04-2022, 09:22 AM | #10 |
Rep 2,393
I am very torn over Ceramic Coating!
We buy/sell/trade cars a lot, so never bothered to ceramic coat them. But this year we ceramic coated our i4 M50, 228i and Porsche Taycan. 228i and Taycan came out amazing....silky, glossy and perfect. When the i4 was in the garage (or shade), the paint looked amazing. When the i4 got hot, or parked in the sun...you could see light swirls, drips, marks and blemishes. Even after the detailer (20+ years experience) came back out 2x....he could not fix it, although he did get it much better. Thankfully when the paint was cool, the paint was gorgeous. He thinks there might have been some residual "moisture" in the i4 paint (it was so new) and it got sealed under the ceramic coating. Either way, I will NOT be doing ceramic coating again. I used Chemical Guys Carnauba Butter Wax on my iX, and it looks and feels as good, if not better than ceramic coating! For $1000+, ceramic coating did not look or feel better than using a high quality wax every 3-4 months. Waxing a car is not fun, but not hard. I just tell myself...it's exercise, calories burned and pride of ownership. Last edited by deutsch100; 10-04-2022 at 09:34 AM.. |
10-04-2022, 10:09 AM | #11 |
Rep 4,504
10-04-2022, 11:56 AM | #12 | |
Rep 303
deutsch1003946.50 Paladin15556.00 |
10-04-2022, 01:23 PM | #13 |
Rep 4,504
It takes me about 15 minutes to spray on apply and buff off XPEL's Detail spray on a dry car after washing. It takes me about an hour (or more) to apply and buff off wax - any wax - properly, on a dry car. Longer for hard paste wax. There are also a variety of polymer sealants that take slightly less time. Regardless of what the manufacturer claims.
deutsch1003946.50 |
10-04-2022, 01:46 PM | #14 |
Rep 303
I decided to go for it. Not a lot of money for what the car costs I guess.
Paladin15556.00 Bornagain73164.00 |
10-04-2022, 02:50 PM | #15 |
Rep 747
I've ceramic coated my last few cars and it's definitely worth it -- but just be aware of what you get from it. Ignore the discussion about its hardness and it gives zero reduction of stone chips, swirling or anything like that. Thought swirls are easily polished out. What it does do is make cleaning your car significantly easier -- and that is a big benefit it my opinion. The car also stays looking cleaner a little bit longer. For example if you get some dust on it, and then it rains steadily it all just beads off nicely.
My RS 3 had a ceramic coat put on it day 1, and it's now 6 years old and the paintwork looks like new, it attracts many comments on how good it looks. On the new M60 we did XPEL Stealth PPF + XPEL Ceramic Coat and I'm not sure if it's the PPF or the ceramic coat, but this is the easiest car I've ever cleaned. Just amazingly easy, all the dust and dirt just falls off the car. PPF provides the stone chip protection.
BMW iX M60, Storm Bay with XPEL Stealth PPF, Exterior Line Titan Bronze, 1EW 22" 1023 Wheels, Amido Leather, Comfort Package, Interior Camera, Clear&Bold, Sun Protection Glazing, B&W Diamond Sound, Folding Towbar, Rear Axle Steering.
10-04-2022, 03:17 PM | #16 | |
Rep 30
Paladin15556.00 |
10-04-2022, 03:37 PM | #17 | |
Rep 2,393
5 mins for the whole car? Maybe if 12 people helping you, LOL. I did the entire car in about 45 mins. Doing this every 3-4 months is not a big deal to me, and while not "fun", I also kind of enjoy it. Pride of ownership |
Paladin15556.00 |
10-04-2022, 04:32 PM | #18 | |
Rep 4,504
deutsch1003946.50 |
10-05-2022, 08:18 AM | #19 |
Rep 138
I had OPTICOAT Pro applied to a new 2019 Cayenne e-hybrid. Around $1,300, and it looked great.
But within months, a bicycle hit the back quarter panel creating a 2" scratch. The car went to the body shop, then back to the coatings guy, who said overspray was was present on other parts of the coated quarter panel. So now the whole quarter panel had to be buffed out, and re-coated. A scratch turned out to be a big hassle requiring re-coating 1/4 of the car. I'm sticking with wax.
2022 iX XDrive50
previous 2019 Audi e-Tron, 2019 Porsche Cayenne e-hybrid 2017 MB E300, 2014 BMW 640i convertible |
deutsch1003946.50 |
10-05-2022, 11:09 AM | #20 | |
Rep 4,504
deutsch1003946.50 |
10-05-2022, 08:38 PM | #21 |
Rep 190
I think proper one is totally worth it. I previously thought it was a gimmick, and actually first time applied it to iX and oh boy, night and day difference. Black color hard to keep clean, but with this thing it is almost clean even after driving in the rain.
deutsch1003946.50 |
10-05-2022, 10:38 PM | #22 | ||
Rep 138
Correcting my ceramic coat took as much time and almost as much money as it cost to repair the scratch in the paint. It was hassle. Even high end auto manufactures don't apply it at the factory. Why not?
2022 iX XDrive50
previous 2019 Audi e-Tron, 2019 Porsche Cayenne e-hybrid 2017 MB E300, 2014 BMW 640i convertible Last edited by jsclarke99; 10-05-2022 at 10:51 PM.. |
deutsch1003946.50 |
