01-01-2024, 08:26 PM | #1 |
Rep 894
Drives: ix xDrive50
Incorrect Time Zone
I’ve been doing my initial round of setup, and I hit a mystery I cannot figure out. When I select set time automatically, it always reverts to the wrong time zone. I can manually override by disabling automatic time setting, but I don’t want that.
Is there a trick to getting it to detect the correct time zone? I am in Eastern Time, but it will always go back to Central Time when I enable automatic.
01-02-2024, 09:50 AM | #2 |
Rep 124
Drives: 2024 iX xDrive50
I can top that… when I check the auto time zone box, it defaults to Croatia and I’m in San Jose, California.
justinguo31745.00 exxxviii1309.50 |
01-02-2024, 04:55 PM | #4 | |
Rep 894
Drives: ix xDrive50
01-02-2024, 05:32 PM | #5 |
Rep 1,457
Drives: 2023 iX xDrive50
BMW typically updates the clock using NTP from cellular carriers. I'm guessing your AT&T or TMobile phones are okay?
Boise and most of Arizona are currently in the same time zone. My computer and iPhone say Cupertino but I know that just means Pacific Time. NomoTesla Does the car also show Boise for the other half of the year when AZ isn't on MST?
Past BMW's
01-02-2024, 05:42 PM | #6 | |
Rep 894
Drives: ix xDrive50
01-10-2024, 05:36 AM | #7 |
Rep 894
Drives: ix xDrive50
Nope. I am pretty sure this is a software defect.
01-11-2024, 01:18 PM | #8 |
Rep 894
Drives: ix xDrive50
My Genius just called me back about the time zone problem. He found a car at his dealership not working, but several others that worked find. It became his personal mission. He spoke with his RTM, and the RTM said that there is a back-end server issue that affected a batch of cars, and mine is one of those cars. He said there should be a fix in the next week or two.
So, crossing my fingers.
330 CSi139.50 |
03-11-2024, 12:43 PM | #9 |
Rep 1,142
Resurrecting this, did anyone find a solution? Mine was working fine until this morning. Realized it didn’t update for the daylight savings change (which is why my departure settings didn’t work), so I figured “I’ll turn it off then back on”.
Big mistake, as it now thinks the car is in “Kabul, Tashkent, Maldives”. While I wish I were in the Maldives for a vacation, I’ll settle for fixing the time zone lol. I tried doing a reset of iDrive which didn’t work, and have tried changing other things around with no luck. Any suggestions? |
exxxviii1309.50 |
03-11-2024, 12:52 PM | #10 |
Rep 894
Drives: ix xDrive50
Mine still doesn't work. I tested it last week, and no change. I returned it to manual time setting and it was fine until the DLS changeover. So, I switched automatic time setting on, then back off, and then I manually corrected my time zone.
This reminds me that I need to give my genius another follow-up call and ask about that rumored fix that was supposed to happen weeks ago...
deutsch1003946.50 |
03-11-2024, 06:02 PM | #13 |
Rep 168
03-11-2024, 08:07 PM | #14 |
2024 BMW iX xDrive50 (iDrive 8.5)
24
Rep 27
I am in Berlin according to ix🫰 I am in California though.
Idrive 8.5 2024 ix50 Last edited by sound1; 03-11-2024 at 11:22 PM.. |
RichardInCA2463.50 |
03-11-2024, 11:13 PM | #15 |
Rep 2,393
2024 i5 same issue. But our M3 and XM (iDrive 8)...automatic time setting & DST worked perfectly (as did all our past BMWs).
Think this is just affecting iDrive 8.5? |
03-11-2024, 11:37 PM | #16 |
Rep 88
03-11-2024, 11:52 PM | #17 |
24
Rep 27
03-12-2024, 05:47 AM | #18 |
Rep 894
Drives: ix xDrive50
That is my guess. When I called my dealer Genius back, he retested it on an i5 there with iDrive 8.5 and got the same result - wrong time zone.
deutsch1003946.50 |
03-14-2024, 02:03 PM | #20 |
Rep 21
Says I'm in China (but really California) - i had to switch to manual setting as it kept putting me back in China
deutsch1003946.50 |
03-14-2024, 03:38 PM | #21 |
Rep 88
Pretty ridiculous. The genius told me it was a daylight savings issues. Clearly not - it's been going on since January!
deutsch1003946.50 Savsearcher161.50 |
03-14-2024, 09:04 PM | #22 |
Rep 131
The time in my 2024 ix has been hosed since DST this past weekend. I attempted to fix it by toggling the auto date/time sync off and on and it just made it worse. I’m going to have to manually set the time now.
