BMW iX Forums BMW iX Discussions
      01-10-2022, 11:17 AM   #1
SteveinArizona
Drives: BMW 530e
Question on ACC
In the new IX, I assume that the car will default to farthest distance which makes it totally useless. So like many people, I coded my current car to default to the closest distance). Can one make that change sticky and, if not, can one code the change?
Thanks.
Steve
      01-10-2022, 11:30 AM   #2
patbrass
Drives: M2 LBB, 6MT
I heard from one of the reviewers that the distance is set to "automatic" by default and adjusts based on speed and maybe other conditions (for example if your wipers are on, I could see the distance augmenting a bit). Not sure if that could be overridden in the settings though.
      01-10-2022, 05:42 PM   #3
SteveinArizona
Drives: BMW 530e
I suspect that "automatic" means farthest. Not good if my suspicion is correct.
      01-10-2022, 05:55 PM   #4
patbrass
Drives: M2 LBB, 6MT
No, I think automatic means it depends. If you're going 100mph on the autobahn, the distance will be set to farthest (as it should). In the city at 25mph, the distance would be much closer. At least this is my understanding.
      01-10-2022, 08:00 PM   #5
nosnoop
Drives: 5 Series
Actually, current BMW no longer does that.
My X5 would remember the last set distance. So once I set it to closest distance, it would stay that way. The only default was when the car was new, otherwise, it would start at "last settings".
No coding is necessary.
I assume iX would be the same in going back to last settings.
In iX, you can either set the distance manually, or use "Adjust distance based on conditions" fully automatic adaptive distance control.
      01-12-2022, 10:23 AM   #6
SteveinArizona
Drives: BMW 530e
That would be great.
      01-15-2022, 05:20 AM   #7
sward
sward's Avatar
Drives: i7 xDrive60
2023 BMW i7  [0.00]
You can set the automatic setting in 3 different distances in iDrive. You can also turn of automatic and set it in one of three different fixed distances.
/Fredrik
i7 xDrive60 -23 Sold: iX -22, X5MC -20 (F95), X5M50d -19 (G05), X5M50d -17 (F15), X5M50d -14 (F15), 116d -13 (F20), X5 3.0D -10 (E70), M3 -10 (E93), 320DX -10 (E91), 320D -08 (E91), X3 30D -07 (E83), 335 -07 (E92), 325 -05 (E90), 320 -02 (E46), 318 -00 (E46), 320 -93 (E36), 318 -89 (E30)
      02-06-2022, 04:20 AM   #8
freshxdough
freshxdough's Avatar
3511
Drives: 2024 iX 50 | 2020 X3 M40i
Thanks.
Steve
They'd have to release coding for iDrive 8 which I'm pretty certain hasn't even been touched yet by coders. Completely new system.
      02-06-2022, 01:40 PM   #9
Rickardg
Drives: iX xDrive40
I would say that automatic is close. In comparecy to F16 i would say iX automatic is same or even closer then the shortest setting in F16. Those who worries that ”automatic” isnt close enough, you dont need to worry.
volodp196.50
