04-03-2023, 08:02 PM | #1 |
Rep 237
My i4 M50 hates going west for some reason
I know that the range calculation is garbage and I am getting 3.1 Miles /KWH so not terrible in Northern Virginia, but, my car has a bizarre glitch imo….I commute 44 miles to my office, it is eastbound in and westbound home. On the commute in, I consistently arrive at the office with more range available than when I leave home (I typically use 16-19% battery on the commute). On the ride home, I always arrive with 75-80 miles less range than when I leave the office. Wonder why going west is so taxing? Commute home has about a 300 foot elevation rise, and traffic is typically worse on the evening commute…other than that, can’t understand the discrepancy. Definitely keep my speed the same and am always driving in B and Eco Pro….
2023 M3 Comp XDrive, Frozen Portomao Blue/Kyalami Orange Black, Valvetronics Full Ti Catback Exh, Eventuri CF Intake, RaceChip Tune
2024 i5 M60 Sapphire Black, Black Veganza 2024 X7 M60i: Tanzanite Blue II Metallic, Tortufo 2023. BMW M1000R Competition BrenTuned |
04-03-2023, 08:35 PM | #3 |
Rep 237
Even after charging while at the office? I typically top off to 80%…
04-04-2023, 12:34 PM | #5 |
Rep 2,011
Drives: 2022 i4 M50
it's amplified given an increase in elevation for OP as well. 300' is nothing to scoff at. I have a 500' gain on my way to drop off my daughter every morning and I'm happy if I achieve 2.0 mi/kWh in the 7 miles there, but I hit about 3.8 mi/kWh on my way back.
@m8cgcdan, have you looked at the average consumption rate on your way to the office vs home? If you're averaging ~3.1 in total and that's your main use, you might be something like 3.6 east and 2.6 west to have that much of a range change throughout your commute... With my experience over the last 8 months I'd say those could be pretty reasonable/expected values for 300 ft. downhill over 44 miles of smooth driving vs 300 ft uphill with traffic.
Current: 2022 i4 M50 | 2022 G07 X7
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC Last edited by unfoundnemo; 04-04-2023 at 01:00 PM.. |
04-04-2023, 05:57 PM | #6 |
Rep 443
Yup elevation sucks as well. My i4 hates going home. Going to work it would use 12% SoC, going home it uses 14-15% depending on how bad the traffic is.
Going to work has more decrease in elevation vs going home but the traffic is 5-6times worse going home. My consumption going to work is 3.9-4.1 but the best I can do coming home is 3.4 |
M3CDan437.50 |
04-04-2023, 06:08 PM | #7 | |
Rep 237
04-05-2023, 08:41 AM | #9 | |
Rep 2,011
Drives: 2022 i4 M50
I just made a 25 mile each-way commute with about a -250' change on the way down. My average on the way down was 3.5... it actually shocked me, as it was mainly highway, and I was running late, so hit some of the corners and onramps hard and was well over 70mph for a good portion of the trip. If I babied it, I likely would have saw something closer to 4. On the way back, I averaged 3.1 with the +250' change (so 3.3). No real traffic here and I calmed down a bit... if I had stop-and-go traffic on some of the up-hill portions on the way back, drove in a similar fashion, etc., the difference between the two would have been much greater, leading to the sorts of GOM discrepancies you see daily.
Gone: 2020 F92 M8 | 2020 G07 X7 | 2018 F80 M3 | 2017 F15 X5 | 2016 F16 X6 | 2015 F36 4 series GC |
