09-05-2021, 08:22 PM | #1 |
Rep 21
DCT Gear Ratio Much Higher than Manual / Torque Converter?
I'm reading the technical data from MINI, and it seems the gear ratios of the DCT is much higher than the manual:
I 3,615 15,741 II 1,952 9,284 III 1,241 5,899 IV 0,969 4,129 V 0,806 3,196 VI 0,683 2,558 VII – 2,073 Rückwärtsgang(reverse?) 3,538 14,220 Achsübersetzung(final drive?) 3,421 3,789 Any reason for this? I think the mini DCT is getrag 7DCT300; getrag also produces DCT for BMW; iirc the M2 DCT is getrag too, but the numbers for M2 is much more reasonable: Getriebeart 6-Gang manuell (7-Gang M Doppelkupplungsgetriebe mit Drivelogic) Getriebeübersetzung I 4,110 (4,806) II 2,315 (2,593) III 1,542 (1,701) IV 1,179 (1,277) V 1,000 (1,000) VI 0,846 (0,844) VII – (0,671) R 3,727 (4,172) Hinterachsübersetzung 3,462 (3,462) I'm not sure if I've read some data sheet from VW, but I vaguely remember that the DSG gear ratios are also close to the manual. Why on earth does mini DCT have such a high gear ratio? Because it has a ridiculously small primary drive??? Tried to google this but couldn't find much useful info; the only thing that come close is from a honda bike forum where the final drive is (slightly) different because of manual/DCT difference. Anybody could answer this? Thanks in advance. |
09-05-2021, 10:50 PM | #2 |
Rep 3,626
no clue. The F80 is like this too. the ratios don't make much sense for the dct and seem to be better for the manual. 1st gear on the dct is short and useless, and 7th gear is just an overdrive gear. My guess is that they made 1st gear short on these cars to prevent people riding the clutch in low speed situations ? but idk.
https://f80.bimmerpost.com/forums/sh...d.php?t=949959
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
09-08-2021, 05:00 PM | #3 |
Rep 2,349
They've made a mistake and multiplied the gear ratio by the final drive. If those ratios were correct the top speed would be about 100kmh
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
09-12-2021, 11:37 PM | #4 |
Rep 21
