11-08-2015, 08:28 AM | #1 |
967
Rep 1,723
i8 Freezes when electric plug won't come out
Went to a friend's house to watch the UCLA-Oregon State game yesterday and used my portable charger. I went out to move the car after it had charged and the charger would not come out of the charging port. And the car wouldn't move as the wheels lock when the charger is in (and whether it is plugged in to an electric outlet or not).
So I called BMW Assist. I was told to remove the cover of the larger access hole in the driver's door sill and pull the blue button. That would release the lock on the charger. Nope. I pulled it and it eventually came off! So BMW called a tow truck for me. With locked front and back wheels the guy hooked up a contraption that went under the back of the car and grabbed the back wheels and jacked them up. He rolled a different contraption under the front wheels, set it up and then jacked up the front wheels as well on a device that had its own wheels. As he jacked it up I heard a "click." The neighbor across the street, who has a Volt, said "let me try to get the plug out. And it came out easily. It was as if the locked wheels being "released" somehow released the plug as well. The tow truck driver lowered the car and took off all the devices, but he followed me in to the dealer where I dropped off the car. (Earlier in the day I had charged the car at a public charging station and getting the plug out then was also problematic.) I'll report on what I find out. Has anyone else had the charging unit stuck in the car?
11-08-2015, 09:35 AM | #2 | |
Rep 11,637
The fact that you used a public charger earlier is interesting. Is there a possibility that it some affected the port physically? Have you experienced any other anomalies regarding charging? Thanks-mk |
11-08-2015, 10:30 AM | #3 |
967
Rep 1,723
I've used the public charger a lot. It's at the GM-Kythera building in Westlake Village. Never had a problem with it -- or the charging port -- before. I've also used my portable charger numerous times in the past without difficulty.
11-08-2015, 11:28 AM | #4 |
iDriver
363
Rep 595
Sorry to hear about the lockup. Glad to know it happened at your friend's place rather than the airport or somewhere less convenient.
Haven't had any problems with the home level 2 unit nor with the available public chargers thus far. Look forward to hearing about your findings. |
11-08-2015, 01:06 PM | #5 | |
Rep 11,637
I am interested to see if this will occur again or if it is a complete anomaly. I use the public charger at Whole Foods and the temp charger daily. Cheers-mk |
11-08-2015, 07:23 PM | #6 | |
Rep 1,177
11-10-2015, 08:17 AM | #7 |
967
Rep 1,723
I spoke to my SA last night. He said there definitely was a problem with the female part of the electric plug and that was being replaced. He hoped the new part would arrive today. He also said there was something else more important BMW wanted checked. He said it was "SEM" but didn't know more than that.
Does anybody have any ideas?
11-10-2015, 03:41 PM | #8 |
967
Rep 1,723
Latest news:
BMW has ordered many parts to replace. Some are small covers, the emergency button to pull open the charger door or release the charger unit, etc., but BMW is also replacing the charger socket and, most importantly, the systems electronic management module. The fact that they're being aggressive leads me to speculate that the SEM module has also been a problem for my i8's brothers.
11-10-2015, 06:41 PM | #9 | |
Rep 1,177
When I scheduled my tire change, there was no work of any other work being mandated by the factory. |
11-10-2015, 06:53 PM | #10 | |
Rep 11,637
How many miles do you have on the vehicle? Thanks-mk |
11-10-2015, 09:52 PM | #11 |
967
Rep 1,723
5394 miles, including 2.5 miles just put on by the dealer.
11-11-2015, 04:12 PM | #13 |
967
Rep 1,723
I met with the i mechanic this afternoon. In order to get to the SEM module, the entire battery has to be removed. The module is on the front. It's about the size of 3 iPhones. (I had thought I'd read that the battery can't be removed.) Here are some photos. The battery consists of 6 units, each slightly smaller than a standard automobile battery.
In addition to changing the SEM module, I need a new charger receptacle which is supposedly being flown in from Germany. I'm counting the days. The last photo is the car from underneath with the battery removed. (The SEM module is being replaced because it threw a code saying it was malfunctioning. It apparently deals with the charging of the battery.)
JasH621.00 |
11-11-2015, 04:23 PM | #14 |
Rep 11,637
Thanks for the update.
It is never fun to see one's toy laid open this way. I was aghast when I saw the M6 in a million pieces. These photo's are very interesting and show that the car is much less complicated than we have been led to believe. My main question is why this unit is placed in such an inaccessible location? This is similar in placement to the electronic control module for the SMG in my M6...placed absolutely in the worse place for service. While I am certain that manufacturing is easier with these placements, for long-term use a better placement would be more wise. Best Regards-mk |
11-11-2015, 05:18 PM | #15 |
967
Rep 1,723
Most eye opening to me was that the battery can be accessed and replaced. So BMW will be able to upgrade the battery when technology changes. And possibly put in a bigger electric motor.
As for the car being completely apart, this was done at the same workstation where my 650i Gran Coupe engine was removed and replaced. As you say, MK, this did not look as complicated.
11-11-2015, 06:20 PM | #16 | |
Rep 11,637
Cheers-mk |
11-11-2015, 11:34 PM | #17 |
Rep 146
Drives: i8 Protonic Blue/Pure Impulse/
Garage List 2015 Ford/Mustang G ... [0.00]
2014 BMW/i8 [0.00] 2015 Jeep/Rubicon U ... [0.00] 1967 Chev 427 Corvette [0.00] |
Tech Failure
Unfortunate event for you, but really interesting findings and exposure of some of the inner workings of our i8's. Hope it all comes together well. Sounds like BMW has gotten after this fairly quickly and aggressively.
Noe....the rest of us will hold our breath just a little, every time we go to unplug our cars! Good luck. |
11-12-2015, 04:14 PM | #19 | |
Rep 92
http://blog.caranddriver.com/all-abo...entire-design/
2015 BMW i8 | 2011 Twin Turbo 1250hp Lamborghini Performante by Underground Racing
11-12-2015, 06:41 PM | #22 |
967
Rep 1,723
That's exactly what I was thinking.
I just got the car back. The receptacle is on order and, supposedly, it won't lock. But I'm charging it now, and it locks. I was able to get the plug out before. We'll see what happens in a couple of hours. Oh, and I lost all the coding. No AM radio, no temperature with tire pressure, no windows and rear view mirrors closing with the key.
