01-05-2015, 04:44 AM | #1 |
Rep 6,673
Yeah, science!
Is there a scientific reason why BMW's (and I guess other cars) always kick the tail out to the right, when traction breaks? I've almost never seen a cars rear end swing to the left.
Also, isn't this something the locking differential should have mitigated? |
01-05-2015, 09:58 PM | #2 | |
Rep 6,690
Normally when the car is moving forward, the rear tires prevent the car from moving sideways, as the torque vector is not particularly sting. But when the wheels spin and traction is lost..... |
01-06-2015, 04:33 AM | #5 | |
Rep 6,673
Smart explanation. Thanks man! |
01-06-2015, 11:21 PM | #6 | |
Rep 20,741
Drives: 2021 911 turbo
Cars can slide to either side. Any angle in the steering wheel will have the greatest impact on which side the car will slide. The incline on the road also has an impact. Since most roads crest in the middle, traveling on the right side of the road will cause the car to slide to the right. Last edited by CanAutM3; 01-06-2015 at 11:35 PM.. |
01-06-2015, 11:29 PM | #7 |
Rep 20,741
That has absolutely nothing to do with it. The picture you posted is simply the convention of how a torque vector is represented in the cartesian referential to indicate in which direction it is applied. There is no actual longitudinal force in the direction of the thumb.
01-06-2015, 11:43 PM | #8 |
Rep 20,741
01-07-2015, 12:20 AM | #9 |
Rep 2,357
My AE86 always step out to the left. Same type diff as the M4...
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
01-07-2015, 07:10 AM | #10 | |
Rep 5,110
As we (or most countries) drive on the right hand side of the road, the car is on the right side of the road and the road surface falls to the right on that side (the road is lower at the curb than it is at the center line). The car is actually sitting at the road with a slight lean towards the right side (and the opposite of course in countries where they drive on the left hand side). When both wheels spin you have the same effect as standing on ice on a slope. You are not sliding up the slope, but down towards the lowest point... And both wheels spinning is necessary for this to happen. If one wheel just rolls, it doesn't loose traction and will steer the car. This effect is therefore more pronounced on a car with a locking diff. Best explanation I can think of EDIT: On a one lane road, the crown is also in the center, which means that the crown on the road is actually under the centerline of the car. On such a road the car should either kick left or right, depending on how centered the car is relative to the crown of the road. On a race track, the road does not have a crown in the center of the surface AFAIK. It's either flat(ish) or in a homogenous angle across the entire surface (at that specific point). This is also true in a corner on a public road. There is no crown in the center of a turn, but rather the entire surface is banked down towards the apex of the corner. Last edited by Boss330; 01-07-2015 at 07:28 AM.. |
01-07-2015, 07:52 AM | #11 | |
Rep 315
Drives: 2008 Deep Green 335xi 6MT
01-07-2015, 08:19 AM | #12 | |
Rep 20,741
01-07-2015, 08:23 AM | #13 | |
Rep 315
It's a game of inertia. But the magnitude is too small to notice. I was agreeing with you :P |
01-07-2015, 08:43 AM | #14 | |
Rep 20,741
If anything, the gyroscopic effect of the spinning wheels will want to keep the car going straight . The gyroscopes in the navigation system of aircrafts are used to calculate changes in direction, a change of direction changes the rotation axis of the gyroscope. When the plane flies in a straight line, the position is established through the ground speed calculated by the on-board accelerometers. Last edited by CanAutM3; 01-07-2015 at 08:50 AM.. |
01-07-2015, 09:27 AM | #15 | |
Rep 315
01-07-2015, 11:36 AM | #16 | |
Rep 1,847
That's why there has been a few airliner crashes over the years as a result of the pitot tubes or static ports being obstructed. http://en.m.wikipedia.org/wiki/Air_France_Flight_447 http://en.m.wikipedia.org/wiki/Birgenair_Flight_301 http://en.m.wikipedia.org/wiki/Aeroper%C3%BA_Flight_603 |
01-07-2015, 01:04 PM | #17 | |
Rep 20,741
There are multiple redundant measuring systems in aircrafts. Air speed measured through a pitot tube is one of the more important measures as air speed is critcal to establish available lift. However, air speed is not much use to precisely establish position since it is practically impossible to measure wind speed accurately. The method you describe is used on small airplanes that don't have elaborate navigation systems, but the pilot will also need to use visual references on the ground to establish his true position. On more sophistcated aircraft, before the days of GPS, navigation systems using accelerometers and gyroscopes were used to precisely establish the position of the aircraft. These inertial systems can still be found in modern aircraft as redundent positioning systems to the GPS. http://en.m.wikipedia.org/wiki/Inert...igation_system Last edited by CanAutM3; 01-07-2015 at 01:14 PM.. |
01-07-2015, 01:24 PM | #18 | |
Rep 1,847
Once the pito-static system quit working, you dont have redudant accelerometers that gives you TAS that's why some airliners crashed. |
01-07-2015, 01:37 PM | #19 | |
Rep 315
01-07-2015, 01:50 PM | #20 | |
Rep 20,741
But oh yes they do, INS systems used accelerometers to establish ground speed and then establish position relative to the ground. And yes, it is old tech. When did I ever mention that accelerometers were used to establish airspeed . I agree, pitot are the only accurate and reliable measure of air speed. |
01-07-2015, 02:05 PM | #22 | |
Rep 5,110
Your profile pic needs updating |
