06-17-2022, 11:34 PM | #1 |
Free Thinker
16910
Rep 7,455
Home Weather Stations
Ok, I know some of you folks have home weather stations set up already. I'm looking for recommendations. I know my wind speed and direction data will be trash because my house is surrounded by trees, but everything else should be accurate. I'm looking for something with wifi capabilities to mount on my shed out in the yard. I have power in the shed, so an AC system is doable. I'm mainly looking for some setup that does not require a monthly (or yearly) subscription and operates on a wifi connection.
06-18-2022, 09:48 AM | #3 |
Recovering Perfectionist
15256
Rep 941
Drives: 2015 BMW i3 BEV
I own a Davis VP2. I also own ~750 stock shares of another company that I won't name, that makes personal weather stations targeting the home market and gives a 15% discount to shareholders.
I'm putting together the stuff to build a second Davis VP2 for installation at our South Carolina tree farm. (I'm also keeping an eye on the used/surplus professional equipment market, with a hope of scoring a professional-grade weather station for home and relocating the prosumer Davis VP2 down to SC.) With that said, I plead the fifth.....
06-18-2022, 10:29 AM | #4 |
Rep 2,010
I have the AcuRite 06058M wireless weather station (not WiFi) and it works well.
This newer version has WiFi: https://www.amazon.com/AcuRite-Weath...07CBFNG3P?th=1
///M235i | Mineral Grey Metallic | Premium Package | Technology Package | Driver Assistance Package | Dakota Coral Red/Black Leather | Harman/Kardon Premium 360 watt sound system | 8-speed automatic
When writing your life's plan, use a pencil with an eraser |
06-18-2022, 12:05 PM | #5 |
your average JAMF
3101
Rep 4,094
Drives: '21 M2 Comp, '19 Golf R
I have a Weatherflow Tempest..
https://weatherflow.com/tempest-weather-system/ It's been up for just over 2 years. In that time, I've had to reboot it twice (simply power-cycle it) because the wind sensor quit. Other than that - 100% reliable. Here's current data.. https://tempestwx.com/station/18897/grid Also integrated with Weather Underground - eazy-peazy setup: https://www.wunderground.com/dashboard/pws/KAZHEREF93 And WindAlert: https://windalert.com/spot/199203
'21 M2 Comp
'19 Golf R Last edited by KevinC; 06-18-2022 at 12:18 PM.. |
06-18-2022, 12:24 PM | #6 |
your average JAMF
3101
Rep 4,094
Also.. connection to base station is wireless with outstanding range, then the base station communications via WiFi to the home network. Unit itself is 100% solar powered.
'21 M2 Comp
'19 Golf R |
06-18-2022, 01:24 PM | #7 |
15256
Rep 941
I hear that there's also a great station driver to import its readings into WeeWX.....
06-18-2022, 02:11 PM | #8 | |
Free Thinker
16910
Rep 7,455
06-18-2022, 02:42 PM | #9 |
15256
Rep 941
...and a great third-party station driver to import its readings into WeeWX.....
06-18-2022, 03:45 PM | #10 |
Free Thinker
16910
Rep 7,455
I'll be pestering you for more info on that once I get this thing up and running.
06-20-2022, 11:38 AM | #11 |
17998
Rep 9,378
I can see why vreihen16 needs to monitor SC remotely, but what are the rest of yall doing?
I have a little LaCrosse that has temp/humidity outside. Change a battery about every 8-10 months. Then the base station in my room is in the wall, and has both internal and external displays, with a weather prediction based on the Hg data I entered. But I don't Wi-Fi connect is so I can see remotely
vreihen1615256.00 |
06-20-2022, 12:47 PM | #12 | |
your average JAMF
3101
Rep 4,094
Take a look at my current data... https://tempestwx.com/station/18897/grid Then, click on some of the individual readings, like wind speed. You get a chart showing speeds and peak gusts, going back hourly. All the data since the station was put up over 2 years ago is there. Same for temperature, rainfall, lightning strikes, etc. And I never have to lift a finger, ever - other than 2 reboots in 2 years. Weatherflow also collects data from these stations and other NWS sources to create a micro-forecast for my specific location. It's consistently 2-3 degrees below the NWS forecast for my (tiny but spread out) home town, and is consistently more accurate. 2 weeks ago it predicted rain 2 days in advance on a day that NWS had the chance of rain at zero at that point. Rain it did. At the bottom of the screen is a map. Click on it and you'll see all the other Weatherflow stations in my area. You can click on any of those and see their data (unless someone has chosen not to display it publicly, which is an option but everyone seems to share). Cool stuff.
'21 M2 Comp
'19 Golf R |
06-20-2022, 02:26 PM | #13 | |
Free Thinker
16910
Rep 7,455
vreihen1615256.00 |
06-20-2022, 06:25 PM | #14 |
Rep 819
I've got an Ambient Weather WS-2902C WiFi station. Don't know how it compares to other stuff, but it does everything I'm looking for
This post sent using 100% recycled electrons.
06-20-2022, 07:46 PM | #15 |
your average JAMF
3101
Rep 4,094
Pretty good chance he shares it on Weather Underground. Check there for stations in your area and you may find it. Or ask him if/how he shares.
'21 M2 Comp
'19 Golf R |
06-24-2022, 02:39 PM | #17 |
Rep 146
This looks really cool. How does that tree affect the wind? I am investigating adding one it is a lot less expensive than I thought. Good Luck keep us posted.
06-24-2022, 08:46 PM | #18 |
Free Thinker
16910
Rep 7,455
My house (and the whole neighborhood) is surrounded by high trees, so there's no getting away from that. I knew going in that the wind data would be local only. This is no surprise as we've often gone out for walks and thought the wind wasn't bad and then once we leave the neighborhood and get out in the open there is suddenly strong wind. But the rest of the data is surprisingly accurate when compared to the local NWS stations. I haven't seen any rain yet, but I'm waiting for that to see how good the haptic rain gauge is.
06-24-2022, 10:24 PM | #20 |
Free Thinker
16910
Rep 7,455
That's temporary until my OEM mount gets here. That's from a floor lamp I used to have in my office years ago when I was toiling away. The base broke and I trashed the rest of the lamp, but I kept the sectional pole because it looked like it might come in handy some day, and sure enough...
The OEM mount from Weatherflow is much nicer looking and sturdier.
kscarrol8907.50 |
06-25-2022, 09:30 AM | #21 |
15256
Rep 941
06-25-2022, 11:52 AM | #22 | |
Free Thinker
16910
Rep 7,455
