06-18-2021, 06:02 PM | #1 |
sportscars only
3244
Rep 3,195
Power-to-weight ratios for some sportscars
Just for fun I wanted to check out some cars I liked in comparison to my existing one. It's always a bit aggravating when they just talk about HP w/o mentioning the car's weight, so I like to know this ratio since it's a better indicator of how a car should perform.
I've lusted after a 4C and always thought that its ratio would be great but according to the figures that I found online, it's only marginally better than my Z4...how could that be? Maybe the figures aren't correct, or somebody mixed up the dry/wet weights? Another nimble car is the MX-5 RF but the ratio is lower, but it's supposed to be near the best bang-for-buck handling car out there....maybe it still is, just that straight-line is not its forte (something like 1 second slower than the other 2 cars). I think the 0-60 times for the Z4 and 4C are near identical, so the ratios there check out, but I'm still sure the 4C must handle much better since it's way lighter. Any other insights? |
06-18-2021, 06:32 PM | #2 |
Rep 145
Where are those numbers from, and which Z4?
The NA spec z4mc S54 motor makes 330hp and 262 ft/lb, and weighs 3230lb which is 1465kg . That gives a .225xxxx. Hp per Kg
Current : 2007 Z4MC, 2010 F650gs, 2018 340i M Performance Edition, 2020 G310gs, 2009 128i
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, Last edited by ToddBlack88; 06-18-2021 at 06:38 PM.. |
06-18-2021, 06:39 PM | #3 |
sportscars only
3244
Rep 3,195
06-18-2021, 07:00 PM | #4 |
Rep 145
Ahh gotcha.
Past : 2001 325 cab, 2002 325xit, 1992 325 M tech ll appearance pack cab, 1990 325is, 1988 M3, 2012 328xit, 2009 M135i cab, 2016 M235i cab, |
06-18-2021, 08:57 PM | #5 |
Rep 3,030
Good luck finding a 4C, prices have gone crazy.
tranquility3243.50 |
06-18-2021, 09:17 PM | #6 |
sportscars only
3244
Rep 3,195
06-18-2021, 10:27 PM | #7 |
Rep 3,617
you probably want to use whp rather than what the manufacturer claims. some under rate some over rate.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
