09-10-2020, 01:58 PM | #1 |
Rep 11,760
Drives: 2018 M4 Comp Indv
All B58 engines now mild hybrid?
Maybe I'm WAAAaaayyy late to the party, but last night I noticed that BMW seems to be releasing *all* their 2021+ *40i sedans as "mild hybrids", that is with a 6 cyl inline ICE + 11 HP e-motor & 48v battery.
In other words, seems like the new standard BMW drivetrain will be electric-hybrid? |
09-10-2020, 02:21 PM | #2 | |
Rep 2,349
Stolen from the future models info thread: The 48V system will expand to other models, possibly even F90. The next likely candidate for 48V is G01/G02. G22/G23 complete worldwide lineup: 420d rwd and xdrive, 430d xdrive, M440d xdrive, 420i, 430i rwd and xdrive, M440i rwd and xdrive. The 48V system is going to be used in all diesels and M440i.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
GrussGott18180.50 |
09-10-2020, 02:25 PM | #3 | |
Rep 11,760
Certainly seems like a prelude to fully electrifying the whole range, and not just an e-only line. The stealth 45e PHEV would also seem to be part of this ... not an i-line, not fully electric, but more than MHEV. |
09-10-2020, 02:58 PM | #4 | |
Rep 19,368
After all, even 12V vehicles (including BMW's) employ start/stop and coast (sailing). Yet, we don't call these hybrids. It's true that the 48V system certainly makes these functions more robust and also adds regenerative braking, and in some manufacturers' (though not yet BMW's) implementations, electric supercharging. Furthermore, some more advanced 48V implementations are built into the engine/transmission, such as the one used by Mercedes, which allows for all auxiliary systems to be electric and completely eliminates belts from the engine. So, yes, the industry is moving toward more robust electric systems in all combustion vehicles, and these contribute small gains in fuel economy. But to classify them as hybrids is a reach, and this is underscored by the fact that, when tabulating HEV sales, they are not included. |
09-10-2020, 03:13 PM | #5 | |
Rep 11,760
Add a plug and now it's a PHEV. Seems to me BMW is going all hybrid, but trying to downplay it with wording, rather than function but ... tomato toMAHto? |
09-10-2020, 03:21 PM | #6 | |
Rep 894
09-10-2020, 03:24 PM | #7 |
Rep 2,349
You guys should check out the weird prototype thread as well where we talk about the electric turbo system from Borg Warner with no wastegate needed - overspeeding the turbine is sorted by the 48v regen ability instead. Plus of course low speed response is helped out by the 48v motor.
https://g20.bimmerpost.com/forums/sh....php?t=1751470
09-10-2020, 03:29 PM | #8 |
Rep 19,368
Yes and no.
If they evolve to a point where the consensus among leading industry trade bodies is to count these mild hybrids as true HEVs, I'm all for it. However, it might be that plug-ins proliferate quickly enough that such evolution never has time to occur. We are already looking at a PHEV heavy lineup from BMW for the coming generation, and others are heading the same direction. As the end of the decade rolls around and we are onto the generation after that, we may be facing rapidly depleting demand for zero-electric-range combustion vehicles. |
09-10-2020, 03:43 PM | #9 |
Rep 11,760
Exactly, in 7 years we'll be saying it's not a full electric because it still has an 11hp ICE
09-11-2020, 12:06 AM | #10 |
Rep 2,349
i3 Rex is calling you from 2013
09-11-2020, 07:37 AM | #11 | |
Rep 156
09-11-2020, 07:54 AM | #12 |
Rep 2,956
Another advantage 48V systems is the ability to use smaller gauge wiring making wire harnesses all over the vehicle smaller and lighter.
09-11-2020, 07:56 AM | #13 | |
Rep 19,368
It's likely true that a belt driven "full hybrid" would not be practical in the real world. Still, it's an implementation detail (even though I agree BMW's is inferior on a purely technical basis). Practically speaking, the real answer to the question "Is it a 'true' hybrid?" is "Does the electric motor move the car on its own or not?". I'd suggest this is the basis on which vehicles are and, hopefully, will continue to be counted / not-counted toward "electrified vehicle" sales (for those keeping score). |
clee1982797.50 |
09-11-2020, 08:01 AM | #14 |
Rep 3,959
Why are the total HP numbers no different if this 48v electric motor is supposed to increase HP by 11? And wouldn't 0 to 60 times be slightly better (maybe the curb weight increased?).
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
09-11-2020, 08:14 AM | #15 | |
Rep 19,368
Secondarily, software can be used to limit total system output. |
clee1982797.50 |
09-11-2020, 08:56 AM | #16 |
Rep 156
The power ratings for the ICE and electric are not additive and I suspect when the ICE is at the RPM level that it is making peak power the electric motor is not engaged. I think I read they are using it for torque fill to increase throttle response. I believe the primary function of this system is to make start / stop much smoother and to add the ability to completely shutoff the ICE when the car is in sailing mode.
09-21-2020, 10:55 PM | #17 |
Rep 1,736
Drives: 2019 BMW 540i xDrive
this 11hp electric can't drive car on its own right (for any real range)? I wouldn't call that hybrid, it definitely makes auto start/stop as close to real hybrid as possible (i.e. much more seamless than the "when I get into my 540 I turn off auto start/stop right away")
09-22-2020, 07:22 AM | #18 | |
Rep 2,665
As long as it all works reliably then I don't think most consumers will care that they have a new system. No extra maintenance, you don't plug it in, you just get in an drive it like every other car.
2006 Z4M Coupe - Stromung exhaust, ZHP knob, stubby antenna, clutch delay delete
clee1982797.50 |
09-22-2020, 01:36 PM | #19 | |
Rep 11,760
✓ Hydraulic steering -> electric? ✓ Electric fans? ✓ Auto stop / start? ✓ Inline electric motor and battery? ◻︎ Electric climate control? ◻︎ Bigger e-motor and battery? ◻︎ Plug-in? ◻︎ BEV? |
