09-20-2019, 10:46 PM | #1 |
Rep 1,762
Drives: Porsche Panamera
I has installed low voltage landscape lights few years ago and they suddenly won't go off in the morning. I tried all the settings and until I unplug the transformer, they stays on no matter what I do, they stay on. Any electrician out there to help out?
09-21-2019, 01:41 AM | #2 |
Rep 2,250
I will take a stab although I don't work with low-voltage lights.....but any "automatic" light that turns on at dark and off at daylight typically works off of a "photo-cell" which essentially is a switch that connects and disconnects the circuit.
I would start there.
wrickem2101.00 |
09-21-2019, 06:27 AM | #3 |
Rep 12,725
are they LED? sometimes LED's can stay on somewhat dim. i think i even remember some audi owners manual literature advising this was normal and the draw is so insignificant that it won't effect battery life... i would imagine the same is true for wired LED's in other applications.
Instagram; @roastbeefmike
09-21-2019, 06:56 AM | #4 |
Recovering Perfectionist
15231
Rep 941
Drives: 2015 BMW i3 BEV
I have had photocells fail twice in outdoor 120V lights over the years, and both times they failed so that the lights were constantly on.
If the cost of replacing the part is too high, buying an external holiday light timer with a photocell built in would let you plug in the transformer and use the existing lights.....
09-21-2019, 07:46 AM | #5 |
Rep 14,522
there should be a photosensor switch on the line. it may have gone bad or covered up with mud, dirt, mulch or something?
RickFLM410968.00 |
09-21-2019, 08:16 AM | #6 |
Rep 4,821
This has been my experience. Even a layer of hard water stains and dust can affect them.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
09-21-2019, 08:52 PM | #7 |
Rep 1,762
Thank you guys!
I think photocell is no longer working. I just order a new part to replace. Thanks! |
09-21-2019, 09:48 PM | #8 |
Rep 11,722
I am not using the photocell sensor; rather, I am using the timer. My experience with photocell sensor is what you are experiencing and the location of the two transformers is in a shaded area. Therefore, those lights will be remain on even during the day time.
10-02-2019, 06:55 AM | #10 |
Coming Soon
254
Rep 960
Remove the photocell sensor and install a google home / Alexa relay to turn the lights on and off at sunset and sunrise via wifi.
https://www.amazon.com/Sonoff-Wirele...0017316&sr=8-8 |
