03-18-2006, 04:21 PM | #1 |
I'm Starving , So I Guess You Are What You Eat
229
Rep 943
How do you take disconnect a sprinkler?
I have one sprinkler head in my apartment complex that waters the front corner of my car. its soooo annoying. i dont really wanna just break the head, cause then water will just go everywhere, and maintence will just come and fix it, plus if they catch me, they are gonna be pissed at me physically breaking it. is there any way to turn it off so water just doesnt come out? if it helps, the hose that feeds it is sticking up out of the ground alot.
2006 325i Sparkling Graphite Metallic-Black Leatherette
Navigation-Bmw Assist Automatic-Xenons Carbon Fiber Front Lips-Aluminum Pedals Power/heated Front Seats 5% Tint all around 30% On windshield all the way down |
03-18-2006, 04:39 PM | #2 |
Rep 109
holy sh1t~! wth is that thing in your avatar?
2006: 325i: Monaco blue with black interior, step, nav, premium, xenon, cold weather, sat.
03-18-2006, 04:43 PM | #3 |
229
Rep 943
i will answer you, when someone else answers me.... I will give you a hint though. It is PROBABLY something you ate for breakfast, lunch or dinner within the last couple of days.
03-18-2006, 04:44 PM | #4 |
Rep 109
erRr... now I'm gonna feel sick.
03-18-2006, 04:49 PM | #5 |
229
Rep 943
haha. i dont blame you. i would feel sick if i ate something that looked like that also.
03-18-2006, 05:15 PM | #6 |
Rep 10,176
Depends on the type of sprinkler head. Most are adjustable to the pattern they spray. Some are not.
You cannot just remove it, unless you find out the diameter of the hose it's attached to, dig around it, detach the existing head, and put a correct size pressure plug on the end of the hose. |
03-18-2006, 05:19 PM | #7 |
Powered By 36DD
337
Rep 7,369
get a small flat-head screwdriver.........and twist the knob counter-clock all the way to shut it off.......
at least that's how mine works....but i'm not sure about industrial sprinklers..... or when the sprinkler comes on....twist the whole thing to spray away from your car....
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
03-18-2006, 05:55 PM | #8 |
229
Rep 943
thanks guys. i will try it tonight. i dont even know when they come on or anything. im willing to invest some time and money into measuring out the caps and stuff. haha. there isnt even that much grass there to be watered. haha
03-18-2006, 05:56 PM | #9 |
229
Rep 943
o. i forgot to uphold my end of the bargain.
thats a pig. well, half of a pig. at a slaughterhouse
03-18-2006, 05:58 PM | #10 |
Rep 6,750
Right, with some sprinkler heads, you can just twist them to divert the spray pattern (if it's assymetric). Like Natureboy said, you can also adjust the spray volume by using a flat-head screwdriver; look for a screw at the center of the spray, and turn it clockwise.
If the spray pattern is symmetric, it may simply need a different sprinkler head. |
03-18-2006, 06:21 PM | #11 |
Rep 1,024
Have you tried asking the people at your apartments if they can adjust the sprinkler head? They may fix it and you won't have to go through the trouble of messing with it yourself. It would probably be in their best interest not to waste water on the concrete/asphalt as it tends not to grow.
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep European Delivery Blog Picture Gallery |
03-18-2006, 07:15 PM | #12 |
229
Rep 943
it technically DOES water crosss. but not too much. PLUS if i ask them, they will say no, that waters our grass, THENNN if i do it after that they will be on to me quicker. but you do have A SMART idea. i just dont think it would work
03-18-2006, 11:25 PM | #15 | |
Powered By 36DD
337
Rep 7,369
03-18-2006, 11:48 PM | #16 |
229
Rep 943
i turned the thing to the right. righty tighty. i should know by tomorrow if that works or not.
03-18-2006, 11:49 PM | #17 | |
Powered By 36DD
337
Rep 7,369
