06-20-2019, 11:29 AM | #1 |
Rep 4,821
Roofing
We have a 21 year old home with a typical FL barrel tile roof. Over the past few years we’ve had a number of leaks repaired and are starting to think about a replacement. . One of the surprising aspects of the first estimate is the differential in roof sq. ft. vs. home total sq. ft. Apparently, the overhangs and roof shape / pitch add about 40% to the home total sq. ft. in our case. I expected a difference but was surprised at how much of a difference.
For anyone who has done this before, how did you get comfortable or self calculate the roof sq. ft.? Other than the obvious reference checks and getting multiple quotes, how did you get comfortable that the roofer you chose was competent?
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
06-20-2019, 11:35 AM | #2 |
Rep 2,232
Geometry my friend, rise over run, slopes, etc. Or you could climb up there with a long tape measure from HD (100'+ for like $20) and do it the manual way.
If you have the architectural/engineering drawings you could use those to easily do the maths. |
06-20-2019, 11:44 AM | #3 |
Rep 2,704
Drives: Built not Bought 04 Z4 VF
On a typical 4 in 12 pitched gable end roof. Roof area is approx 25% more than floor area.
Thats taking into account a 2' overhang for soffits both sides Having a multi pitched roof will add to this substantially.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
06-20-2019, 11:52 AM | #4 |
Rep 14,398
Steepness.
How cut up is it. ie, a lot of valleys. High number of valleys equals more waste. Your insurance carrier 'should' have the number of total squares, 10x10, in their records. Fyi: Be wary of the really low and high bids. Too low means they will likely surprise you later. The really high bid means he really doesn't want the job unless he can high gross you. What is under the tiles? Old composite over decking? Decking only? Slats? Peek in your attic...
Crazy Diamond
RickFLM410968.00 |
06-20-2019, 12:24 PM | #5 |
Rep 4,821
Here are a few pics of front, rear and attic (each taken right before Hurricane Irma), as well as a pic of a valley issue that needed repair this week. It gives and idea of what’s under the tiles - plywood with some type of membrane. House is 2,645 under air, 3,641 total incl. garage and covered patio / entry. First estimate has us just above 5,000 sq. ft. (or 50 squares) for roof.
I am weary of any roofing contractor because I am pretty ignorant on roofing. I’ve been trying to read up but it’s a bit overwhelming... This is not going to be a find-the-lowest-cost-guy project. I don’t want to do this more than once or be dealing with preventable issues a few years down the road. At the same time, just picking the highest quote guarantees nothing. I need to figure out how to educate myself enough to get comfortable with who we select and how they will do the job. Good tip on insurance. I’ll check paperwork. I hesitate to call them right now in hurricane season because if they get the idea we are thinking about replacing the roof the fuckers might try to drop us. Insurance in FL sucks.
06-20-2019, 12:27 PM | #6 |
17980
Rep 9,377
Man, I bet you get ALL the local channels.
Sorry, I have nothing but poor humor to contribute, I'll show myself out |
06-20-2019, 12:32 PM | #7 |
Rep 4,821
Yeah we can actually pick up local channels as well as those in Miami, which is nice because every once in a while they have different football games. We don't really use the antenna much anymore though. Mostly DirecTV and streaming.
06-20-2019, 12:33 PM | #8 | |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
06-20-2019, 12:36 PM | #9 | ||
Rep 1,965
Nice house btw! |
06-20-2019, 12:36 PM | #10 | ||
Rep 4,821
06-20-2019, 12:41 PM | #11 | |||
Rep 4,821
Numerous neighbors replaced roofs over past few years. I planning on talking to as many as I can.
06-20-2019, 12:42 PM | #12 |
Rep 2,704
Rick,
Thats a 6 in 12 pitch and lotsa valleys etc. 40% more is fair for SQ/FT
RickFLM410968.00 hooligan_G016430.00 |
06-20-2019, 12:48 PM | #13 | |
Rep 1,965
RickFLM410968.00 |
06-20-2019, 12:49 PM | #14 |
Rep 8,852
No - our deck is uncovered.
RickFLM410968.00 |
06-20-2019, 12:54 PM | #15 |
I'll get back to you
7559
Rep 2,132
43k for a roof?!?! holy sh!t. thank god for shingles. and living out of hurricane zone I guess.
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
RickFLM410968.00 IllSic_Design2124.00 |
06-20-2019, 12:56 PM | #16 |
Rep 14,398
Calm down lol.
They can't make you sign their contract, even though they'll probably hound you if they're slow right now. Ding ding ding on neighbors. If there cost was lower, relatively same size home, don't freak out. Materials are basically commodities. Asphalt jumps the most but I'm guessing so do barrels. Decking bounces too. If they run into bad decking DO NOT LET THEM JUST COVER OVER. Having a few sheets in their order is peanuts. Don't let them convince you otherwise. Fyi: Before seeing the house I guessed 40-50. That shite is heavy and those guys have to get paid. Also have to take it all and unload at the dump...$ per pound. I'm rusty but I think you'll want that old composition stripped off. Unnecessary weight and heat conductor. All those ticky tac charges they mentioned sound squirrelly. The sales rep should look you in the eye and you in turn trust he or she. If they give you the willys...think twice. Get payment squared away BEFORE you sign. Some weasels will try and get start up payment, 1/3 usually, and then the balance immediately upon completion. You pay in full when completed, inspected by foreman and your yard is spotless. If they can't afford materials and need start up monies...PASS.
Crazy Diamond
06-20-2019, 01:09 PM | #17 |
Rep 4,821
Definitely plan to talk to neighbors. We aren’t jumping into anything. It will either be this winter or next. Summer is a bad time to replace your roof here due to rain and storms. So we have time, although there is a long lead time to get the tiles.
When we have a significant repair, generally the plywood is cut out and replaced and that section is effectively new. So I was expecting ALL plywood and fascia to be replaced. I’ll find out how neighbors have seen it handled, but it seems odd to me to not replace it everywhere, other than in spots that were recently repaired and therefore the plywood is new.
06-20-2019, 01:11 PM | #18 |
Rep 448
$18 gets you satellite pic measurement
https://www.eagleview.com/?from=adwo...BoC54AQAvD_BwE More details costs more Call em up, I'm a contractor, I use them Notes: rule of thumb on payment schedule here in Massachusetts, no money up front, 1st 1/3 check when material is on site, 2nd 2/3 (remainder) after all work and cleanup is finished |
06-20-2019, 01:14 PM | #19 |
Rep 14,398
If the majority of the decking has not felt water, there's really no reason to replace it. It would be nice and comforting, but add another 2ish to 3 grand. Decking is spensive.
Crazy Diamond
06-20-2019, 04:40 PM | #20 | |
Rep 685
I've owned two contractor companies for 15 years now and if you aren't willing to put money down then I automatically assume YOU are the weasel. I can afford to float jobs and do all the time for regular clients but never for new. There are way too many scammers out there on both sides. I fully research clients before starting by checking county databases, saved me many times when you see multiple contractor liens against them. This all said some people pay their deposits with credit cards, most of the time they don't even clear before the job is done. This rule just saved me two weeks ago. Potential client kept ignoring the deposit requirements so I passed, county showed liens. I give current clients 30 days to pay. |
06-20-2019, 04:55 PM | #21 | |
Rep 4,821
NEfan5082658.50 |
06-20-2019, 05:01 PM | #22 | ||
Rep 448
Check data base? No way, I see a customers face and I make the decision if I'm going to work for him/her lol, I'm not sears, I'm not looking for headaches Doing this all my life, since before I could drive, I've had 1 job and 1 job only, people skills is a good part of it To OP, when you hire someone be smart, first check references (visually) ask if they've done work around you, Trust your gut, plan B is go to a supply house near, hangout for an hour, talk to some customers (roofers) give them your details for a price, it's nice to get 3 bids minimum |
RickFLM410968.00 |
