      04-09-2015, 05:37 PM   #1
JasH
JasH's Avatar
Question Tyre pressures on i8
My i8 has the Turbine wheels, so are a little wider than the standard ones.
The manual states that the correct tyre pressures can be found on the door pillar of the driver's door. It is not there I checked both doors.
I tried googling to find the correct tyre pressures too, but with no luck.
I ended up just guessing, and filled each front tyre to 2.35 bar and each rear tyre to 2.4 bar.
Does anyone know the correct pressures please?
      04-09-2015, 05:53 PM   #2
Epirali
Drives: BMW e Copper i8 Roadster
I'll check shortly on mine and post in an hour or so. I know mine were on the door, want to say 32 psi but not sure.
      04-09-2015, 06:09 PM   #3
MalibuBimmer
MalibuBimmer's Avatar
2018 Mercedes AMG GT  [0.00]
2018 Audi Q3  [0.00]
2015 BMW M4  [10.00]
Correct. I have turbine wheels, too. I fill all 4 to 33 ppsi. Just because.
      04-09-2015, 07:16 PM   #4
Epirali
It is indeed 32 psi for my us turbine wheels. The sticker is on the underside of the driver door itself, not the door panel.
      04-11-2015, 03:49 PM   #5
JasH
JasH's Avatar
Thank you Epirali and Malibu
      04-11-2015, 08:11 PM   #6
MalibuBimmer
2018 Audi Q3  [0.00]
2015 BMW M4  [10.00]
Has anyone else enabled the temperature readings for the 4 wheels? v12 did it for me and it's fun to watch. The tires sitting in the sun get a bit hotter but it doesn't seem to affect pressure.
(I also have AM radio -- which is essentially unusable because of the interference -- and a suite of features unavailable in the U.S. My BMW USA contact said that if I wanted to know if re-coding would affect my warranty to ask my dealer. And my dealer said no as long as it wasn't related to the powertrain.)
      04-11-2015, 08:28 PM   #7
Epirali
Oohnwhat other fun features do you have? Can you auto roll up your windows by lock or remote app?
      04-12-2015, 12:55 PM   #8
JasH
JasH's Avatar
fyi, for metric reference in case anyone needs, 32psi is 2.2 Bar.
(So it seems I filled mine to 34/35psi....will need to let some air out.)
Tags
tyre pressures
