04-18-2015, 07:03 PM | #1 |
iDriver
363
Rep 595
Wide e-mile variance with level 1 cord
Noticed a wide variance in the number of e-miles achieved when charging with the regular 110V BMW power cord. Charging after short trips, 5 miles or less, the battery shows 14-15 e-miles when charge is complete. Whereas, 19-22 miles of electric charge is achieved after driving for at least 18 uninterrupted miles. Not sure if the increased e-miles has to do with: charging when the vehicle's motor or undercarriage temperature is hot; the ambient temperature of the garage (the higher charges occurred during warmer evenings); charging during off peak electric hours;or a combination thereof. Anyways, pleasantly surprised to get up to 22 e-miles with just the standard 110V cord that comes with the car.
04-18-2015, 07:27 PM | #2 | |
Rep 578
04-18-2015, 07:59 PM | #3 |
967
Rep 1,723
The proof of the pudding will be in the number of electric miles you can get before the ICE kicks in. I've tricked my car's computer into thinking I could go 29 miles on electric only from coasting hills. But as soon as I started out the electric range would drop precipitously. As I've noted elsewhere, the best I've gotten is 21.3 and 21.0. I typically drive 14 miles electric only and have 3-4 miles left (or so says my car's computer).
04-19-2015, 01:58 PM | #4 | |
iDriver
363
Rep 595
Interesting point though, to see if the remaining e-miles are indeed accurate or just a rough guesstimate based on analyzing the previous trip or driving habit. |
04-20-2015, 11:01 AM | #5 |
iDriver
363
Rep 595
It seems that there is a definite difference in obtaining more e-miles on a recharge when either the ambient temperature of the garage is warmer or if the i8's motor and undercarriage is warm as well. Not sure which. Could possibly be a combination thereof. Performed a recharge early this morning with car sitting cold overnight and garage temperature at 62 degrees F. (16 degrees C.), which yielded only 14 e-miles at maximum charge.
04-20-2015, 12:10 PM | #6 |
Rep 578
You should search in another thread about mileage, there is a lot of information. Many things, including ambient temperature, tire pressure, headwinds, elevation, driving style all significantly impact battery capacity and/or range/efficiency. Cold reduces power available in the battery AND makes the air more dense, impacting range. For example in a Nissan Leaf the range difference from a nice warm summer day (when battery has stabilized) vs a cold winter day can be a 40% reduction in range. And batteries have a good amount of thermal momentum, so they don't change quickly.
Its common to all electric cars. |
04-20-2015, 12:46 PM | #7 | |
iDriver
363
Rep 595
