01-16-2022, 03:36 AM | #1 |
BMW Miniature Collector!
13325
Rep 7,980
BMW i4 M50 - first impressions and driven until it dies [RSymons RSEV]
Some first impressions on the BMW i4 M50 from RSymons RSEV. Plus find out what happens when it is driven until it dies.
01-26-2022, 02:48 PM | #2 |
Rep 6,572
He followed up with a lengthy comparison to the Model 3.
As a Model 3 owner, but not having experienced the i4 in the flesh in any way, I think most of his points are accurate. However, he's a bit jaded in some areas toward the Tesla. Namely the infotainment. Having used iDrive 7, I can say that the "native" BMW nav system that he keeps 'whinging' about (as he says) isn't nearly the poor relation compared to the Tesla that he makes it out to be. Also, he kind of complains about the central gauges in the BMW not being configurable enough. My answer would be: at least it's got gauges! Also, he goes on quite a bit about the i4 interior feeling like it could be in a 320d. Yeah, the Tesla interior feels like it could be in a 120d so not sure what he's on about there. I felt like his observations about the drawbacks of not being on a dedicated EV platform (central tunnel size, no frunk, high dash height) are warranted. These are things that you quickly grow used to as being a benefit to the Tesla. Especially the low dash. The forward visibility is as outstanding as the rearward visibility is horrendous. LOL. Also, I feel like his ever so slightly small swipe at the Tesla's suspension being "stiff" is understating things. It's not stiff. It's bad. It does not carve corners at all. It nibbles at them. It's crying out for a good set of coilovers. I do like the very quick steering ratio, though. All in all, an interesting comparison. |
01-26-2022, 03:24 PM | #3 |
Rainbow Racer
1008
Rep 2,539
It's bias, but reviews typically are. The build quality commentary is interesting, he must love hard touch plastics.
Which Model 3 do you have? I enjoyed flinging around a M3P during a test drive at the Tesla store here, but I should say I was more impressed with the steering ratio vs actual suspension dynamics as it wasn't at-the-limit handling. Made it easy to fling around and I can certainly see why people enjoy it. |
01-26-2022, 04:25 PM | #4 | |
Rep 6,572
Initially, it feels impressive. The steering is quick, with zero slop. It's very easy to initiate a turn and the car pivots quickly. And if you're on smooth roads, you probably won't notice much of an issue. On less than smooth roads, it quickly falls apart. First off, the ride, even on the straight ahead, is, shall I say, perfect if you have a bobble head on your dash. Check out the attached video from my dashcam. pay attention to fixed horizontal items, like power lines, overpasses and road signs. Watch them for a few seconds and see how they oscillate up and down? That's not the camera, that's the whole car doing that. The car pogos. The reason is that the suspension relies heavily on the bump stops for damping, and the suspension travel is short, resulting in the car being on the bump stops much of the time. Second, when you encounter bumps like this while cornering, the rear of the car is easily upset. You don't have to be pulling g's to feel this. It's evident even making a lazy turn. it's not to say that the car gets out of control, however if you do the same run back to back say in a BMW or a Porsche, the lack of composure from the Tesla is immediately apparent. Unfortunately, many 'reviewers' think "stiff is sporty" and the quick steering and sharp turn in seduce many into thinking the car is better than it is. But it isn't. As far as "build quality" goes, the Tesla again fools the untrained. There actually are few hard plastics, especially in the refreshed Model 3's where the center console is padded. The whole door card has a soft touch coating on it, all the way down. The only hard pack is on the underside of the horizontal trim bar (wood or white), inside the door cubbies, and on the center console. The seats are soft and comfortable, the steering wheel feels good, the horn module has a nice padding to it, etc. But when you start knocking on things, you realize it's a veneer. Thump on a Porsche door panel and you're greeted with heft. The Tesla is feather light. It's stiff, but tinny. Pull the side panel off the center console and it's barely stiff enough to hold itself horizontal. By comparsion, the center console of a BMW feels like it's made of plywood. Tesla saves cost...and weight! A Model 3 is somewhere like 800 pounds lighter than an i4. That doesn't just "happen". But life is about tradeoffs. And if you were coming out of, say, an Acura, you probably would never know what you were missing. |
01-26-2022, 05:39 PM | #5 |
Rainbow Racer
1008
Rep 2,539
It looks like the 2022 model 3's have hard touch lower door panels all around now. I live in FL where the roads are fairly smooth, so I did not notice bumpy road items. However, now that you do say that, I do recall the rear-end feeling out of step even when navigating a simple round-a-bout at like 25-30ish MPH and going over raised pedestrian cross-walks and the rear end feeling like it was attached to a beam-axle suspension where they side-step over the bump.
I haven't cancelled my order yet for the M3P though, I'd like to live with it for just a few days before coming to a full conclusion. I have an M50 on order as well.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
01-27-2022, 07:30 PM | #6 |
Rep 4
Having just put a deposit down on a i4M50.... the range that tester (video in post #1) got is quite concerning.... 180 miles til dead? it didn't look that cold...
I was hoping to make the roundtrip with the wife next year with the skis in the back to our hill 280km round trip without charging.... maybe not... usually it's about -5 to -10c when we go skiing... Looks like I may having to find and park at a charger when we go skiing.... (not conveniently located).... |
01-28-2022, 02:25 AM | #7 |
Rep 18
Some of the results from å big range test i Norway. All the cars drove the same route at the same time. i4 M50 made it 406km in winter conditions.
Written in norwegian, but the table should be posilble to understand. https://motor.no/aktuelt/motors-stor...elbiler/217132 |
4monks95.00 |
01-28-2022, 03:20 AM | #8 | |
Rep 253
mlello16.50 |
01-28-2022, 03:54 AM | #10 |
Rep 253
01-28-2022, 04:45 AM | #12 |
Rep 28
Thanks. 19” summer tires could be getting close to 450km actual range. I have 19” wheels coming due to range For winters I could even go for 18”. Any way that will be topical only next winter and depends on what kind Scandinavian winter tire selection will be available, I also prefer non-studded tires.
01-28-2022, 11:44 AM | #13 |
Rep 4
thanks for the Norwegian info.... might help me for my Southern Ontario winters.... We live at about 43.4N latitude, the ski hill I go to is 44.5N.
I try to get there 5-10x/winter for a couple hours each time... it's about 145km 1 way. currently no convenient chargers along the route.... --- just mapped the route on google maps that the Norwegians took... similiar style roads that I take to get to my ski hill... 80kph posted speed limit, most go 95kph.... but with a turn or stop sign every 15 km or so... Last edited by Petee_c; 01-28-2022 at 12:22 PM.. |
01-28-2022, 01:10 PM | #14 |
3099
Rep 3,470
Can you explain this chart to me? I'm a really newbie to EV's. Thanks.
01-28-2022, 04:34 PM | #15 |
Rainbow Racer
1008
Rep 2,539
Very surprised by a few things...
The i4 M50 scoring as high as it did for being one of the "least efficient" cars, and also the quickest accelerating cars on that list. For as cold of a test that was, this will bode well for someone like me there we have flat roads and normally 75F and above throughout most of the year. The iX 40 scored lower than the iX 50, by a good margin. |
01-28-2022, 04:36 PM | #16 |
Rep 8,008
Drives: i4M50
I watched all his reviews on the i4M50 and it does seem at odds with my own findings. How can he say the interior isn’t any better than a 320d as if that’s a bad thing, the build quality of recent BMWs is probably better than any of its current German rivals which puts it comfortably ahead of the Tesla. I agree the Tesla’s sat nav is brilliant especially when linked to finding charging points, that’s one thing no one does it better but as a basic sat nav the one in my M5C has never let me down.
Ride quality is very good on the i4, it soaks up almost everything and it’s quiet too… two areas where both differ is throttle response and steering input, despite the badging on the i4 this is no M car it’s a cruiser that just happens to be fast which in my mind isn’t a bad thing. Was reading about the i4M50 vs M3/4 vs Tesla 3P in Car magazine, when it’s available on-line hopefully in a week or two it’s worth reading. |
01-31-2022, 11:02 AM | #17 |
Rep 4,210
"Also, he kind of complains about the central gauges in the BMW not being configurable enough. My answer would be: at least it's got gauges!"
Yes. The lack of gauges and the lack of a HUD disqualifies any Tesla 3 or Y as far as I am concerned. In some ways Tesla is like a cult (I don't mean this negatively...all religions are cults). You either sign up for Elon's way or you don't. Personally, I greatly admire everything he has accomplished but not the man himself. But, then again, this is not uncommon for great achievers. |
