      11-18-2020, 01:36 AM   #1
soheil
Drives: 2018 i3 REX
How long can I drive with flat tires?
As I was starting the car today noticed that one of the rear tires is flat. Called the nearest tire shop and replacement will arrive tomorrow. How long can I drive with this tire? The shop is only 1.3 miles away, is it ok to drive or should I go there and pick up the tire and replace it myself?
      11-18-2020, 08:38 AM   #2
vreihen16
Recovering Perfectionist
vreihen16's Avatar
Drives: 2015 BMW i3 BEV
If you turn the wheel half a rotation (assuming nail is on the pavement now) and put air in it, will it hold for a few minutes? If not, pull the wheel and take it to the tire shop if you have a jack.
Obligatory warning about i3's being totaled by an errant jack or lift arm puncturing the carbon fiber chassis because the factory jack points weren't used.....
soheil64.50
      11-18-2020, 01:16 PM   #3
soheil
Drives: 2018 i3 REX
Good suggestion about holding the air, I will test this. And thanks for the comment regarding using factory jack points
      11-20-2020, 07:41 PM   #4
JohnWasser
JohnWasser's Avatar
Drives: BMW i3
If the tire won't hold air long enough to drive 1.3 miles you could try the Fix-A-Flat goop that comes with the electric tire pump in the frunk.
The "Tire inflating bottle, 350ml" (part number 71106871122) is available online from various BMW dealers for about $24.
Search this Thread:
Advanced Search
