      04-10-2024, 07:21 PM   #1
Cwelch
Cwelch's Avatar
16
Drives: BMW 535xi drive 2009
2009 535xi drive  [10.00]
Need help!
What’s the best transmission fluid for my bmw e60 bmw?
      04-11-2024, 02:02 AM   #2
M3SQRD
M3SQRD's Avatar
2172
Drives: E92 M3,G20 330ix,F22 240iX,F82
MT or AT?
      04-11-2024, 05:49 AM   #3
No one
Drives: F21 118i
Originally Posted by M3SQRD View Post
MT or AT?
AT: MT has no transmission fluid, only oil, AFAIK.
      04-11-2024, 06:09 AM   #4
Cwelch
Cwelch's Avatar
16
MT or AT?
Its AT transmission
      04-11-2024, 06:18 AM   #5
M3SQRD
M3SQRD's Avatar
2172
They sell fluid labeled as automatic trans fluid and manual trans fluid. Was asking for clarification…but automatic transmission fluid (ATF) serves several purposes such cooling, lubricating, transmitting force, and acts as a hydraulic fluid with special additives to prevent foaming, rust, and wear whereas manual transmission fluid primarily lubricates gears and reduces friction.
FYI, OP was looking for AT, not MT, trans fluid.
      04-11-2024, 06:51 AM   #6
M3SQRD
M3SQRD's Avatar
2172
Its AT transmission
Pentosin ATF1 if you have a green or black sticker on your trans.
What year and e60 5-series model do you have?
      04-11-2024, 06:58 AM   #7
No one
Drives: F21 118i
That looks like they don't want you to know what you disclose below then.
That's how I got it and posted FYI.
      04-11-2024, 07:21 AM   #8
M3SQRD
M3SQRD's Avatar
2172
I’m not sure what point you’re trying to make? BMW offers ATF and MTF (e.g., MTF LT3, MTF LT5, etc.). ATF and MTF are sold regardless of the type of fluid.
      04-11-2024, 08:00 AM   #9
No one
Drives: F21 118i
I mean ATF is a multi-purpose "fluid" but MTF is effectively "oil": I double-checked it, BMW does not offer "engine fluid", it's "engine oil" (that "lubricates gears and reduces friction", to my knowledge). Never mind, your request for clarification was correct then , but their terminology seems misleading/inconsistent.
      04-11-2024, 04:20 PM   #10
Cwelch
Cwelch's Avatar
16
I have a 535x I drive and it’s 2009!
      04-13-2024, 09:15 AM   #11
RockCrusher
Drives: BMW 2023 ZB M2 6-speed
The car is a 2009 and I assume the transmission is ok. Thus I'd offer whatever transmission fluid BMW calls for.
      04-13-2024, 09:34 AM   #12
RockCrusher
There are gears in an automatic transmission. Also in both manual and automatic transmissions gear teeth have an involute shape and thus experience a rolling motion against a mating tooth.
As an aside I don't know how common it is but some manual transmissions can be designed to use (require) ATF and not the more viscous manual transmission lube.
My 1996 Mustang GT and its 5-speed manual was one such transmission.
      04-13-2024, 09:54 AM   #13
M3SQRD
M3SQRD's Avatar
2172
Yes. I’m aware of their being gears in an AT. All I did was ask the OP to clarify whether it was an AT or MT, considering BMW sells both.
