12-29-2022, 06:43 PM | #1 |
Rep 5,796
Drives: 2024 BMW XM Label
Not sure where the fuse panel is on the iX since I don’t have it yet, but has anyone done a direct wire for their radar detector? Luckily the BlendMount that I have on my M550 will fit on this vehicle, but not sure what fuse block to use for the fuse tap. I can’t use the MirrorTap option because I am also using the Escort ZW5 laser shifter andi it’s direct wire cable has an extra module in it to communicate with the radar detector wirelessly.
12-29-2022, 06:50 PM | #2 |
Rep 377
On a realted subject, does the iX have a metallized windshield that blocks RF signals such as radar and transponders (eg., EZPass)?
VirtualGuitars7869.50 |
12-29-2022, 08:21 PM | #3 |
BMW Aficionado
1381
Rep 1,850
12-29-2022, 08:24 PM | #4 |
Rep 5,796
12-29-2022, 09:00 PM | #5 |
Rep 377
12-29-2022, 09:02 PM | #6 |
Rep 437
Ez pass will only work on the top dotted areas. Contrary to the instructions which made it seems otherwise.
12-29-2022, 09:03 PM | #7 |
Rep 5,796
12-29-2022, 09:06 PM | #8 |
Rep 437
I don’t use one. But, I know my ez pass works in that dotted area.
12-29-2022, 09:10 PM | #9 |
Rep 5,796
12-30-2022, 12:15 AM | #10 |
Rep 39
I have the TX Tag on the non dotted area (right of the mirror) and it is working correctly (successfully detected by multiple toll agencies). The front wind shield has IR rejection, but I don't think it has metallic elements (someone can confirm though).
12-30-2022, 06:58 AM | #11 |
Rep 314
My radar detector works just fine stuck to the lower left part of the windshield.
12-30-2022, 07:38 AM | #12 |
Rep 5,796
12-30-2022, 07:44 AM | #13 |
Rep 376
Drives: BMW iX60-2024
Garage List 2016 BMW X5m (retired) [0.00]
2016 BMW M4 (retired) [0.00] 2022 BMW iX 50 (ret ... [0.00] 2024 BMW iX m60 [0.00] |
My NTTA toll tag works just fine within the dotted area also just to the passenger side of the camera assembly (in case anyone wants to know if that experiment has been run).
12-30-2022, 07:49 AM | #14 | |
Rep 377
I noticed one response saying it does work in the cabin. If it does, it's with significantly reduced sensitivity. |
12-30-2022, 07:53 AM | #15 | |
Rep 5,796
12-30-2022, 08:38 AM | #16 | |
Rep 377
Understand your conundrum about the rental cars. I have a Valentine One that's about 15 years old in my other vehicle, but since some car mfrs started using K-band sensors for their adaptive cruise control, I find it virtually useless. In my Escort, I programmed it to ignore K-band as it's not used in my area. |
12-30-2022, 08:55 AM | #17 | |
Rep 5,796
12-30-2022, 02:13 PM | #18 |
Rep 5,796
Found this BMW website that will let you download any fuse chart by entering your VIN:
https://fusecard.bmw.com/ |
12-30-2022, 04:00 PM | #19 |
Rep 11
I bookmarked this page for fitting a dashcam - https://www.********.com/threads/pow...-detector.942/ - the install shown is for a radar on an i4.
12-30-2022, 05:52 PM | #20 |
Rep 5,796
Thanks For sharing that. I actually read that earlier today. The problem is I can’t use a MirrorTap even though I have one lying around. I’m using the direct wire cable that came with my Escort ZW5 that communicates to the detector wirelessly. It doesn’t power the laser shifter receiver directly, but I still have to use that proprietary cable. I have to go to the fuse box, but luckily it looks to be easily accessible underneath the dash near the center console.
01-07-2023, 06:35 PM | #22 |
Rep 437
