      06-20-2020, 04:55 PM   #1
stressdoc
stressdoc's Avatar
Dominica
618
Michelin Pilot Sport 4S and Acer titanium lug bolts
I made the plunge. Put on a set of Michelin Pilot Sport 4S and Acer titanium lug bolts.
Sizes: front 235/40 20, rear 265/35 20. Fronts are pretty tight, only about 1 or 2 mm clearance on inside. Tires are about 2 lbs. heavier each, 20 mm wider. Car sits about 1mm lower.
Acer bolts are 1.75 lbs. for full set (20); stock are 3.25 lbs., so some of the weight gain from wider tires is offset.
Initial impressions: ride, noise, steering, and handling are significantly affected.
Ride: much smoother.
Noise: much quieter, almost no rumble from moderate or even rough surfaces. Pavement divisions and lane divider dots have clear 'thump' sounds, more noticeable given the much reduced background noise.
Handling: I have not sorted this out yet. Clearly more grip, but the car tilts a bit more from the extra outside grip, so this will take some getting used to. Reduced understeer - the front does not break easily. I have not pushed beyond about 8/10ths so this is still unexplored.
Steering: heavier, more precise, better feel, less vibration. Smooth.
      06-20-2020, 05:40 PM   #2
MGRMLN
Drives: 2015 Nissan GT-R Black Edition
Give the tires some miles to wear off the mold release compound and get to the real tread before you go pushing too hard
2019 Volcano Orange McLaren 570S Spider
2019 Carrara White Porsche Cayenne
