09-01-2011, 02:29 AM | #1 |
Rep 21,240
BMW Developing Laser Headlights to Replace LED In Future
BIMMERPOST NEWS BMW Developing Laser Headlights to Replace LED In Future BMW develops laser light for the car. 01.09.2011 Following the introduction of the full LED headlight, laser light is the next logical step in the development of vehicle headlight technology. BMW is planning this step, thus further expanding its lead in innovative light technology. Munich. As a globally successful carmaker within the premium segment, the BMW Group attaches the utmost importance to advanced technology in all sectors of automotive manufacturing. Exclusive innovations and technological leaps secure BMW’s lead amongst the competition. In the field of exterior vehicle lights, BMW also leads the way for example with full LED headlamps for the BMW 6 Series and with new developments such as the “Anti-dazzle High- Beam Assistant”, as well as with “Dynamic Light Spot”. The term “Dynamic Light Spot” stands for a marker light system that automatically illuminates pedestrians in good time, thereby guiding the driver’s attention. After LED technology, laser light is the next logical step in car light development. BMW engineers are currently already working on the introduction of laser light as a further pioneering technology for series production within a few years. Laser light could then facilitate entirely new light functions for even more safety and comfort and at the same time contribute significantly through its higher degree of efficiency towards a saving in energy and fuel respectively. Laser light produces virtually parallel light beams. By definition, laser lighting is radically different from sunlight, and also from the various types of artificial lighting in common use today. For a start, laser lighting is monochromatic, which means that the light waves all have the same length. And it is also what is known as a “coherent” light source, which means that its waves have a constant phase difference. As a result, laser lighting can produce a near-parallel beam with an intensity a thousand times greater than that of conventional LEDs. In vehicle headlights, these characteristics can be used to implement entirely new functions. Also, the high inherent efficiency of laser lighting means that laser headlights have less than half the energy consumption of LED headlights. Simply put, laser headlights save fuel. The intensity of laser light poses no possible risks to humans, animals or wildlife when used in car lighting. Amongst other things, this is because the light is not emitted directly, but is first converted into a form that is suitable for use in road traffic. The resulting light is very bright and white. It is also very pleasant to the eye and has a very low energy consumption. Laser diodes are already in use today in the consumer sector. Completely safe laser lighting technology is already in use in a variety of consumer products, though in many cases this is a product feature that goes unnoticed by the customer. That won’t be the case when this technology is used in cars, however, as planned by BMW. Here the whole point is that the advantages should be noticeable and visible. A further feature of laser technology, which has important implications, is the size of the individual diodes. With a length of just ten microns (µm), laser diodes are one hundred times smaller even than the small, square-shaped cells used in conventional LED lighting, which have a side length of one millimetre. This opens up all sorts of new possibilities when integrating the light source into the vehicle. The BMW engineers have no plans to radically reduce the size of the headlights however, although that would be theoretically possible. Instead, the thinking is that the headlights would retain their conventional surface area dimensions and so continue to play an important role in the styling of a BMW, while the size advantages could be used to reduce the depth of the headlight unit, and so open up new possibilities for headlight positioning and body styling. A further advantage of laser lighting technology, and one which the BMW engineers intend to use to full effect, is its high inherent efficiency. A single statistic will make this clear: whereas LED lighting generates only around 100 lumens (a photometric unit of light output) per watt, laser lighting generates approximately 170 lumens. With statistics like this, it is not surprising that BMW is also planning to take advantage of laser lighting technology to increase the efficiency of the overall vehicle. And appropriately enough it is in a concept vehicle from the new BMW i sub-brand, the BMW i8 Concept, that laser lighting will get its first airing. After all, BMW i stands for a new premium concept that is strongly oriented towards sustainability. Laser lighting: high efficiency and safety. Safety is a key consideration in the development of laser lighting for use in passenger cars. For BMW, the complete eye safety of this technology for all road users and its complete reliability in day-to-day use have top priority. Importantly, therefore, before the light from the tiny laser diodes is emitted onto the road, the originally bluish laser light beam is first of all converted by means of a fluorescent phosphor material inside the headlight into a pure white light which is very bright and pleasant to the eye. As a result, in future it will be possible to use laser light to implement all the familiar – including more recent – BMW lighting functions such as Adaptive Headlights, the “Dynamic Light Spot” spotlighting system and the “Anti-Dazzle High-Beam Assist”. It will also be possible to use BMW laser lighting to implement completely new functions, which will have only minimal power consumption. |
09-01-2011, 07:13 AM | #3 |
Rep 4,109
Drives: BMW M3
Definitely cool. Looking forward to seeing this in production.
Lighting is a very important safety issue. Coming from a car with halogens to the projector bi-xenons in my BMW, I'll not get another car without them. Same goes for the cornering lights and turning headlamps, I miss them immediately driving other cars. Both improve safety a lot.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
09-01-2011, 08:53 AM | #6 |
Rep 1,410
I should love to be a fly on the wall at the engineering meetings. Conversations would sound like this,
Head engineer: LED headlight were a success, but we need to step up our game, any ideas? Engineer 1: How about lasers? Head Engineer: that sounds crazy futuristic, outrageous, almost impossible and very costly. Not to mention, no one would dare do it.....I like it, lasers it is
09-01-2011, 08:53 AM | #7 | |
Rep 1,410
09-01-2011, 09:15 AM | #8 |
Rep 1,278
Fire Teh Layzarss
PAST 2007 Black Sapphire E90 335i, 2010 Jerez Black E92 M3, 2012 Mineral White E92 M3, 2013 Singapore Grey F10 M5, 2016 Azurite Black F80 M3,
CURRENT 2017 Oxford White GT350 |
09-01-2011, 09:18 AM | #9 |
Rep 712
My Valentine V1 will go crazy when it sees laser headlights!!
SOLD - 2007 BMW 335i Sedan, Montego Blue with Lemon seats, AluFelgen CS7 rims & Continental DW tires
CURRENT - 2018 Chrysler 300S, Crystal Granite Metallic. |
09-01-2011, 09:43 AM | #10 |
Rep 1,855
Just wait until someone tries to mod their laser headlights and messes it up. Think: Depo laser headlight retrofit install gone horribly wrong on some large truck where it's lights are at your eye level...
Now, we have a lot of blind drivers.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
09-01-2011, 09:43 AM | #12 |
Rep 884
Drives: 2007 BMW 335i
I love how they talk up lasers soooo much, and then in the last paragraph they mention that little tidbit about how they really only use them indirectly through phosphorescence. Of course it's probably needed because a single laser can't make white light... maybe they can make RGB arrays and then you could just choose your own color...
I guess it could provide useful features, but it's not like you are shooting an array of tiny lasers beams out in front of the car to light things up.
Current: 2007 335i sedan
Alpine White | Sports | Premium | Cold | Comfort Access FORMERLY: 128i coupe Alpine White | Sports Package | Black Leather |
09-01-2011, 09:52 AM | #14 |
Professional Trophy Husband
25
Rep 150
+1! Like we don't have enough trouble with all the Infiniti SUVs and their "always-on" laser cruise control. Hopefully, BMW won't be using RED lasers for the headlights, so detectors shouldn't be affected.
09-01-2011, 09:57 AM | #15 |
Rep 2,218
^ for sure!
- 2014 CPO i01 BEV Electronaut Edition Capparis White Tera World, '17- - 2015 CPO i01 BEV Laurel Grey Tera World, '17- - 2015 i01 REx Laurel Grey Tera World, '15-'17 - 2003 CPO 330i ZHP Imola Red Build 03/03/03, '06-'15 |
09-01-2011, 10:08 AM | #16 |
Rep 619
Whole new reason for the H8TRS to hate.
2008 E92 M3, ESS VT-1, AA Full Exhaust, Volk TE-37, PSS10, ST BBK, ARKYM Motorsport Spliter, Vorsteiner Diffuser, BMW Edition Grill/Gill's, BMW Performance Spoiler, AUTOcoture Blacked Out Headlights, LCI Tail lights, Vorsteiner Carbon Fiber Center Dash Insert, Ultimate Racing Pedals (Because Race Car), AA SSK, Speed Cloth. |
09-01-2011, 10:17 AM | #17 |
Rep 29,202
For most poeple Xenon is the future.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
09-01-2011, 10:22 AM | #18 | |
Rep 21,240
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
09-01-2011, 10:43 AM | #19 | |
Rep 790
- Finally, we come to my number two man. His name? Number Two. |
09-01-2011, 10:53 AM | #21 |
Rep 1,177
Bad news for Laser Police detectors.. they will freak out
Alpine White, Coral RED , Glacier Silver Aluminum trim, M sport, 6MT, NAV, HiFi, USB-iPod, Bluetooth
Performance: JB4|BMW PE|DP Cosmetics: BMW Sport Pedals|Black Kidney Grill |
