08-13-2018, 10:40 AM | #1 |
Rep 71
Laser headlights vs regular
The car I found has Laser headlights. Was wondering if anyone has ever compared both in an I8?
It's only for high beams going over 40mph it seems. They are, $6,000 option. Last edited by Jason B; 08-13-2018 at 10:52 AM.. |
08-13-2018, 02:24 PM | #2 |
Rep 157
Only works above 43mph, only works with auto high beam function. Meaning you can’t manually turn them on. It is, however, quite noticeably brighter than the regular high beam under 43mph. Is it worth it? Subjective but it also adds the second LED bar on the day time running lights which looks a lot better than the single one with the base headlights. Oh and the lasers cost $7600 (each) retail to replace if damaged. It mostly depends on how much you value the DRL look and how often you realistically use high beams
08-13-2018, 04:25 PM | #3 |
Rep 1,904
Worth every penny. Quite a bit more light. See here:
https://www.bmwblog.com/2014/11/25/e...dlights-night/
alfredjdavisjr9.00 |
08-13-2018, 06:02 PM | #4 |
Rep 157
Blog is referencing European version of the lights which are significantly brighter than the weaker US version. You can tell the difference by the yellow warning triangle sticker (federal law to have it) on the US version. US version is still bright but nowhere near the EU one
08-14-2018, 09:24 AM | #5 | |
Rep 1,904
08-14-2018, 09:29 AM | #6 |
Rep 157
https://www.bmwblog.com/2015/06/23/l...ed-in-the-u-s/
Im sure there are more but that article says 2x for US and 3x for EU. Anyone that followed the laser light technology will know this is true as well. I have the laser lights also |
08-14-2018, 09:32 AM | #7 |
Rep 157
Also:
http://www.bimmerfile.com/2015/11/17...ing-to-the-us/ https://electrek.co/2015/11/25/bmw-i...n-the-u-s/amp/ “However it’s worth noting that laser lights in the US will be around 30% less powerful than their Euro equivalents.” |
08-14-2018, 09:39 AM | #8 |
Rep 1,904
Ack! Well, color me in denial...
Those documents are all from 2015 and appear to have been born of the same source info (as much of them is identical). Is there anything more recent supporting this as well? Denial aside, I'm wondering if this could be modified with coding (like cars with adaptive headlights)...
