      09-28-2018, 01:52 AM   #1
slamboogie
slamboogie's Avatar
Drives: 2014 BMW i3
220 Extension Cord recommendation
I just purchased the BMW TurboCord Charger. Would like to use an extension cord to connect this to my 220 outlet to this charger.
My question are as followed:
1. Is it safe to use an 220 extension cord to connect to an Level 2 charger?
2. What type of extension cord rating and specifications I should look for
3. Any brand specific extension cord I should purchase and stay away from.
      09-28-2018, 09:20 AM   #2
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
Technically no, the manual says not to use a cord with the charger.
If you HAVE to, the TurboCord requires a NEMA 6-20 plug on a 220/240 20a circuit, but really runs at I think like 18a. At a minimum you would need a cord +5a for every 6-10 feet. For 6 feet or less you might be ok with a 20a extension cord. Not sure if there are NEMA 6-20 cords, surely they aint cheap. Could always make your own.
I'm sure you wouldnt be the first to do it.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX
2021 X7 40i MSport, 2006 Z4M 6spd
      09-29-2018, 02:42 AM   #3
slamboogie
slamboogie's Avatar
Drives: 2014 BMW i3
Thanks Bagekko for your input.
The spec for the dual 110/220 dual charger is rated for level 2 at 3.6kWh/per hour but I think it is charging at twice of the spec rating at 7.2kW/per since my 2014 i3 battery capacity is at 33kWh (per i3 user manual).
Is my calculation correct?
33kWh divided by 7.2kWh = 4.5 hrs (full charge) this is my experience.
Link to the charger I bought on Amazon:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      10-01-2018, 11:35 AM   #4
bagekko
bagekko's Avatar
2018 M4 Vert  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
The BMW Turbo Cord is not level 2, its like level 1.5 as some of us call it. It takes more like 9-10 hours to fully charge the 33kw 94a battery from empty.
