11-04-2018, 09:01 AM | #1 |
Member
Rep 37
Drives: 2015 i8 Pure Impulse
Auto shifting into S6
So...when I am in Sport mode the gears shift automatically up until S5. But regardless of how fast I am going it will not shift automatically into S6 and I have to manually pull the right paddle to shift into M6 to drop the RPM. Could not find anything in the manual and my dealer gave me a blank stare. Does anyone know if this is normal or is it a service issue?
Lotus Evora S
RR Sport SVR |
11-04-2018, 09:28 AM | #2 |
Rep 157
It’s normal although I don’t agree with it. You’ll get used to having to manually shift to M6 in order to use less fuel at higher speeds. Annoying part is manually shifting back to auto S shifting once you hit traffic again and need to slow down
11-04-2018, 12:19 PM | #4 |
Rep 578
11-05-2018, 03:55 PM | #6 |
Rep 157
Yeah it’s kind of annoying to hold it because you have to hold it about 2 seconds and you can usually flip the shifter to comfort and back faster than that which also isn’t ideal. Wish it was something like hitting both shifters simultaneously would put you back into sport auto (similarly to how it puts some other cars into neutral)
11-07-2018, 05:38 PM | #7 | |
Rep 1,177
11-07-2018, 05:57 PM | #8 | |
Rep 1,177
That said, automatic shifting and fast driving are a contradiction in terms to me. The gearbox doesn’t see the road or the traffic in front of you. If you want to be fast, your eyes determine the shifts, nothing else. |
11-08-2018, 02:57 PM | #9 |
Member
Rep 37
I fully agree....this is my first automatic performance car. I routinely drive on open highways at 85-90 mph. Shifting occurs through the gears at about 3200 rpm. But in S5 I can continue to increase my speed and it will never upshift until I do it manually into M6. Doesn't make any sense to me....but if that's the way it's designed, so be it.
Lotus Evora S
RR Sport SVR |
