11-08-2018, 01:51 PM | #1 |
Rep 47
Winter Tires Recommendation
Hello All, I am wanting to enjoy my i8 Roadster this winter in Northern Michigan and am wondering if I can get recommendations on the proper / best winter tire w/ rim option. Thoughts???
11-09-2018, 10:05 AM | #3 |
Rep 47
11-09-2018, 02:59 PM | #5 |
Rep 578
Actually this is not true. If you have summer performance tires the compound will break down and we damaged even and cold temperature, much less in contact with snow. So it’s not just about traction but it’s about protecting the high-performance tires.
11-09-2018, 03:13 PM | #6 |
Rep 283
The summer tires should not be used when the high temp falls below 40F.
11-09-2018, 04:25 PM | #7 |
Rep 1,904
Tirerack.com is your friend.
Just ask their website to pick a winter tire/wheel package for your i8. For example: - Pirelli Sottozero 3 235/45R19 ($214 ea) on - Ultraleggera HLT Gloss Black 19x8's ($458 ea) They will mount them (inc TPMS), balance them, and ship them directly to you...
Epirali198.00 |
11-09-2018, 06:05 PM | #8 | |
Rep 157
11-12-2018, 10:39 AM | #9 | |
Rep 1,904
20 inch rims are used for mounting "pretty" low profile tires. However, no one makes snow tires in a low profile application. Snow tires almost always require a smaller rim (especially on "sport" vehicles). Nothing wrong with mounting 19 inch rims on your i8 to accommodate Snow Tires... They will fit just fine. Go to TireRack.com and run the query for a winter wheel/tire combo...
11-12-2018, 10:45 AM | #10 | |
Rep 1,904
I took my i8 out this weekend after a dusting of snow just to see how it handled. I'm sure the car is quite capable with PROPER tires, but my factory summer rubber was completely out of control. I wasn't pushing it at all and the car had great difficulty completing slow speed turns and even coming to a stop in a parking lot! (Maybe 1/2 inch of snow). I wasn't really expecting much, but those summer tires are absolutely dangerous with even a dusting of snow! It doesn't make much difference if the car is AWD if the tires can't get any traction!
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 11-12-2018 at 01:45 PM.. |
11-12-2018, 01:44 PM | #11 |
Rep 1,904
Here's a screen shot of an i8 Winter Tire/Wheel combo from TireRack. $2833.20 including TPMS, Lug bolts, lug bolt adapters, centering rings, Mounting, Balancing, and Shipping. Everything you need... Done! (Note that TireRack even lists cheaper wheel options):
