07-10-2019, 05:18 AM | #1 |
Rep 23
BMW i8 MAP - Sensor placement
Hello there.
Does anyone have any pictures or tips on how to reach and plug in a new adapter on the MAP connector? Trying yto install a tuning kit from Essing Performence but i can localize the damn connector. Anyone have any tips? |
07-10-2019, 09:15 AM | #2 |
patsgarageonline.com
100
Rep 170
I looked at the i8 Training Manual on page 22, item number 4, and found the location of the intake manifold pressure sensor. I believe this is the same as the MAP sensor you are referring to but I'm not sure:
http://www.rotory.com/bmw/I8.pdf I also found a picture of a long block and it appears that this same sensor is the one in the photo with the brown wires connected to it: https://www.pacificmotors.com/wp-con...48312481-3.JPG If this is true, then this area is covered with acoustic covers. You'd have to remove the top acoustic cover on the engine by pulling straight upward. There are 4 rubber grommets keeping it attached to the engine. Then, try to remove the acoustic cover just in front of that one, to get to this sensor. It's a tight area. |
