      11-25-2012, 06:28 PM   #1
SixBanger
Drives: 08 135i
Need help with removing iaantmon.exe in msconfig
Can someone show me how to remove iaantmon.exe file in msconfig under startup tab? I can find the file name on my list.
      11-27-2012, 08:40 AM   #2
Rhodes7586
Drives: 2011 335i x-drive
You will probably have to show hidden files and folders. Then try browsing to the directory that the file is located in and remove it.
      11-27-2012, 10:59 AM   #3
Templar
Templar's Avatar
Drives: 2011 E92 M3
2011 BMW M3  [10.00]
Why are you trying to remove it? According to what I have found it should be left alone.
http://www.neuber.com/taskmanager/pr...ntmon.exe.html
http://www.processlibrary.com/direct...aantmon/25716/
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel
      12-05-2012, 12:39 AM   #4
SixBanger
Drives: 08 135i
I've been encountering a buzzing/lag when playing songs, movies, and TV shows through itunes or any other player. Disabling that file would end all of my issues.
      12-06-2012, 12:35 AM   #5
G33K
Drives: 2009 328i
Rather than remove the file just disable it in msconfig by unchecking it so that it does not run when the computer is started.
If you are OCD like me and want to keep the msconfig list clean without any unchecked items then instead of disabling it in msconfig you can remove it from the startup location so that it does not run on startup.
To do so, look at the entry in msconfig and check under the location column. This should either be the startup folder in which case just browse to that folder and remove that shortcut from there or it will be a registry location, in which case you will have to make changes to your registry. You will need to get to the specific location specified in the location column and remove the iaantmon entry. You can google the microsoft website on how to access the registry and how to make changes to it just make sure you make a backup of the registry first and also sset a restore point, just in case.
Search this Thread:
Advanced Search
