11-18-2016, 05:07 PM | #1 |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
Brake Upgrades: Any options?
I've heard a few folks mention that the brakes are their biggest gripe about the car. So I'm curious...has anyone seen or done any BBK upgrades? Do you think we could get enough interest for someone to get a kit working for us?
11-18-2016, 05:26 PM | #2 |
Rep 1,299
Drives: 2015 BMW i8
My limited technical and engineering knowledge may fail me here but wouldn't this affect the rehén breaking in some way? If so, I'd be reluctant to try this.
2015 BMW i8 in Matte Metallic Grey:
H&R Springs 21" ADV.1 ADVNL2 MV2 CS Wheels Coming Soon: 2016 BMW M4 GTS De-Winged and Bagged on 22s |
11-18-2016, 05:35 PM | #3 | |
Agent Smith
270
Rep 3,344
Drives: 2016 i8
That being said, I didn't notice anything that stood out. I don't think regenerative braking has anything to do with the physical brakes on the wheels...I think it's all in the electric drive itself. |
11-18-2016, 05:45 PM | #4 | ||
Rep 687
Drives: Ferrari 458, BMW i8, Acura NSX
11-19-2016, 08:07 AM | #5 |
Rep 2,352
Drives: 16' BMW i8
Garage List 2001 BMW M3 E46 CON ... [9.50]
2016 BMW i8 [10.00] 2003 JEEP GRAND CHE ... [0.00] 2000 540i SPORT E39 [10.00] 2007 TOYOTA TACOMA ... [0.00] |
What is this gripe of which you speak of? I feel like my brakes are fine. Other than some herky jerky movement before coming to a complete stop, which I am attributing to the regen braking system, I feel like it performs as advertised.
11-19-2016, 11:16 AM | #6 | |
Driver
301
Rep 382
As you lift off the gas, the car starts using the front electric motor to slow the car. You get a max of about 50% of the braking torque here. (watch the gauge). As you press the brake pedal, the car will first use the front electric motor to further slow the car. You can see this as the gauge goes to 100% regen. If you apply more brake pedal force at this point, the car will start engaging the hydraulic brakes to the braking forces of the electric motor. The anti-lock and traction control systems will now balance the braking forces of the car, managing the electric motor's torque and the hydraulics. Changing the hydraulic brake system (with different pads, different rotors, or even different calipers) won't affect the car's computer systems. They are already programmed to be constantly adjusting to varying levels of brake friction (to compensate to wear, temperature, etc.) The only possible issue would be installing different calipers that might exceed the capacity of the hydraulics system. Are you taking the car on the track? If not, you probably won't be (shouldn't be?) exceeding the capabilities of the brakes. If you just want a more aggressive bite for street driving, go put some track pads on the front. Ignore the rear. But be aware that they might not work better until they've achieved optimal temperature... which is nearly impossible in (legal) street driving. Go see a brake expert. Zeckhausen Racing is a good start. (but I have no idea if he has pads for the i8)
Aye-eight508.50 |
11-19-2016, 05:25 PM | #7 |
Rep 1,177
Makes total sense. The only caveat is that the computer managing regen vs. braking may have been fed with some parameters about the brakes from the factory. That may lead to awkward situations, e.g. in terms of brake force applied by the system. Youmay end up with wheels locking up faster than the ABS is expecting. Same goes for the assisted braking function when you get too close to an obstacle. You certainly wouldn't want the car to misjudge braking force required in this situation.
11-19-2016, 07:44 PM | #8 | |
967
Rep 1,723
11-20-2016, 03:28 AM | #9 |
Rep 1,177
True. My point is that if the control computer had certain parameters about the brakes programmed in, the reaction of the brake system could be unpredictable if the brakes reacted more sharply than anticipated. Maybe it's a non-issue. But the i cars are different from normal cars in that the brake force needs to be balanced between regen and actual braking. BMW went to quite some length to get it right.
11-20-2016, 03:35 PM | #10 |
Driver
301
Rep 382
Attached is a little light reading about how the brake system actually works.
Aye-eight508.50 iHyperMiler13.50 |
11-21-2016, 11:29 PM | #11 | ||
Rep 1,405
11-22-2016, 04:57 PM | #12 | |
Rep 1,177
Makes me less inclined to mess with the system. |
Louv300.50 |
