01-30-2018, 03:37 AM | #1 |
Rep 112
Charge point access
Hi Guys, I am looking at purchasing a 2015-2016 i8 in the next few months. I am from the UK so my steering will be on the opposite side of my charging point. I wish to install the charger inside my garage on the front wall. Only issue is if I drive the car into the garage I will struggle to gain access to the car socket as it will be close to a wall.
Will I be able to plug the lead into the car before driving into the garage, then connect to the charger? Or will the car not drive with a lead connected? |
01-30-2018, 09:33 AM | #2 | |
Rep 407
In my garage, I've got a couple of chargers (an EV and the i8), sometimes I park the i8 close to the wall with the charge port facing the wall (and I mean close - wing mirrors within an inch of the wall so I can park my X5 or Zoe in next to the i8). Even this close, I can lean over the front of the i8 and pop the charge cable in no problems. As long as you can get to the front of the car, you'll be fine as the port isn't too far back.
2014 i8
2002 x5 4.6is |
01-30-2018, 06:19 PM | #3 | |
Rep 84
01-31-2018, 10:33 AM | #5 |
Rep 112
If i back it in I won’t be able to get out of the drivers side due to the garage wall. I also checked last night, my current car F30 has around 8 inch clearance from the front wall. I think the i8 is a longer car. |
